Loader FEL hydraulics
   / FEL hydraulics #1
pay1920
Piedmont
Bobcat CT335sst
I noticed yesterday when I was tilting the bucket forward to dump a bucket of dirt, the bucket would not tilt, instead it kept trying to tilt back, I looked this morning and found one of the hydraulic lines had come disconnected, Is there anything I need to do other than re-connect the hose? After I reconnected the hose, the FEL felt weak, Should I be able to lift the front wheels off the ground with the bucket tilted foward and lowered? I'm new to the tractor world, I have a Bobcat CT335sst. Will I have to bleed any air from the system? Or am I just too worried about nothing, Thanks, Pay1920
   / FEL hydraulics #2
No bleeding (loosening lines) required. Run the engine at about 2000 RPM and raise loader off the ground then roll bucket all the way back and hold lever for a couple seconds, then dump it all the way out and hold again. Do this 2 -3 times and it should be fine.
   / FEL hydraulics
Thanks Dennis, I'll give this a try, Steve
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
2014 Club Car Carryall 295 4x4 Utility Cart (A59228)
2014 Club Car...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
iDrive TDS-2010H...
