Loader FEL Hydraulics
/ FEL Hydraulics #1
bill18163
NW Pennsylvania
Kubota B2710,BX1860,LA3940
The FEL on my B2710 Kubota will not go in the down direction with any amount of force. All other directions have hydraulic force. The down direction is VERY slow. If you release the down valve by pushing the stick all the way forward it will go down very fast. But it doesn't work under hydraulic pressure. Anyone have any ideas????
/ FEL Hydraulics #2
Two things, take all your quick connects off and reconnect them. Sometimes they seem tight, but aren't. The other thing is the valve at the bottom of the joystick can get gunked up. I don't have any experience with this, but there are balls and stuff in there that can get hung up. If you think thats the problem, hopefully someone will give better advice on that one.
/ FEL Hydraulics
Dodge Man,
I did remove and re-connect all the quick disconnects but that didn't help. Can you describe more in depth where this valve is and should I open it up some how and try to clean it out?
2023 WALLACE-THE ROOSTER ROOT PICKER PINTLE HITCH (A65057)
2023 WALLACE-THE...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2009 CATERPILLAR CS56 SMOOTH DRUM ROLLER (A65056)
2009 CATERPILLAR...
2010 Freightliner M2 106 Pac-Mac KBF 20H Forestry Grapple Truck (A66736)
2010 Freightliner...
PORTA POTTY (A67714)
2013 CHEVROLET CAPRICE POLICE CAR (A66091)
2013 CHEVROLET...
