FEL Hydraulics on M7030
   / FEL Hydraulics on M7030 #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
My loader works off one set of remotes. So, when using the loader, I have to lock the remote lever back and, in that position, the 3-point hitch and the other remote doesn't work. I have been living with it but wish I could run the loader and the 3-point at the same time. This was discussed at one time, and I realized it was way over my pay grade. Can someone explain it to me again and how expensive it would be to have a professional fix/change it.
Thanks
   / FEL Hydraulics on M7030 #2
To start with, some photos of the loader valve, how/where it's mounted would go along way toward answering your questions.
If the valve is power beyond capable (this can be determined from out here with proper photos) then the cost will not be all that much. Just some creative plumbing, hoses and fittings, miscellaneous hardware. You well may be able to "do it yourself" with proper instruction. It's actually simpler than you think. It all depends on who you listen to, what actual "Kubota" parts (if any) you decide to go with.
   / FEL Hydraulics on M7030 #3
Aftermarket loader maybe? OEM Kubota loaders are plumbed directly far as I know. At least both of mine are.
It is a Quickie Q750 and here are some pictures.
   / FEL Hydraulics on M7030 #5
That explains that. Kubota OEM loaders all have integral hydraulics and the return line dumps into the gearbox (in my case) on the back cover of the PTO. My only suggestion would be to add another valve set, which you can do as the valves are stackable. maybe someone else has a better suggestion, I don't.
   / FEL Hydraulics on M7030 #6
There should be some blocked off fittings down by the filter on the right side of tractor. Just in front of the filter. Kinda at front of passenger foot board. Some can just plumb in, some you will need a plate, or block bolted in there.
   / FEL Hydraulics on M7030 #8
This might help you out some.
  • M7030SUDT.pdf
Wooden Sleigh (A50774)
John Deere MX5 3pt 60" Rotary Mower (A50774)
John Deere MX5 3pt...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2020 Kinze 3505 High Speed 6/11 Planter (A52748)
2020 Kinze 3505...
2007 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2007 Ford F-150...
