FEL/Hydraulic Question
/ FEL/Hydraulic Question #1
kawallace
North Carolina
Kubota B7500HSD
The tree root got me..... while using my FEL to move some dirt I got caught in a root and blew a hydraulic line. While removing the line that blew I inadvertently disconnected the wrong one at the quick connect end. I need to reduce the pressure on this line to reconnect and I have tried moving the contorl lever to no avail.....any suggestions on reducing the hydraulic pressure so I can reconnect this line ? Also any ideas on how much a new line will cost ?
Thanks, Wally
/ FEL/Hydraulic Question #2
Wally, I'm not sure what you're talking about. If it's pressure in the quick coupler at the valve, then moving the control lever around, with the engine off, should do it. If it's pressure in the line that's disconnected, then put a drift pin against the pin in the center of the coupler, wrap a rag around it to catch the surplus, and one sharp rap on the drift pin with a hammer will do it.
Bird
Bird thanks for the info, it is the line that needs the pressure released so I will give your solution a try. Is a drift pin like a flat ended punch ?
Wally
/ FEL/Hydraulic Question #4
<font color=blue>Is a drift pin like a flat ended punch ?</font color=blue>
Yep, that's what it is. If you're like most of us, you'll find someday that you took your loader off in cool weather and start to put it back on in hot weather and the increase in temperature has increased the pressure in the lines, and you'll have to do that to one or more of the lines to get them hooked up again.
Bird
/ FEL/Hydraulic Question #5
A few dollars ($10 to $20) is typical of new hydraulic lines. They are relatively cheap considering how much goes into them. The line should not have blown regardless though of the load. If you try to lift the Empire State Building with your loader all that should happen is a no lift situation and fluid after reaching maximum PSI will be bypassed. That is the real beauty of hydraulics. The hose must have had a weak spot. Rat...
I was surprised to say the least when the line blew. The break was where the rubber hose is connected to the coupler. Wally
Bird I used your suggestion with the drift pin and bingo no more pressure. Have reconnected and now will head to the dealer for a replacement hose on Monday. Knowing how to do things sure makes it easy, again thanks for your advice.
Wally
/ FEL/Hydraulic Question #8
Wally, glad that part worked out well. I've been wondering whether you had a defective hose that blew out, or whether you hung that root in the hose and pulled it apart. At any rate, I'm sure you'll take the old hose with you to get the new one. Lots of places custom make the hoses and end connections, so they can easily duplicate your old one.
Bird
/ FEL/Hydraulic Question #10
Scruffy, I think all the NAPA stores are franchise stores; i.e., individually owned, so I suppose prices vary. When I was doing my Top 'N Tilt, I had the hoses made by the tractor dealer (same company, but different location from where I bought my tractor because they were 25 miles from home instead of 50). A rancher neighbor told me he'd had hoses made by that tractor dealer AND at the NAPA store (same distance) and said they were about the same price. AFTER I had it done, another farmer neighbor told me the Farmer's Co-op (14 miles from home) makes them cheaper and uses better quality hoses./w3tcompact/icons/laugh.gif My usual luck with whatever I buy./w3tcompact/icons/laugh.gif
Bird
Bird I believe it was a defective hose as it blew by the crimping of the connector. I took the old one to the Kubota dealer where I bought the tractor and they made a new one for $10.25, quite a baragin I thought. I am now back in operation and trying to finish digging out a small pond. Wally
/ FEL/Hydraulic Question #12
Bird, you are correct in your assumption that Napa stores are franchise operations. It was only about 15 miles to the Napa Dealer, and 35 to the closest tractor dealer, but when you consider city traffic that I had to go through on 6 or 24 of those miles, the extra cost was well worth the price! Plus, I wanted it now, not later!
I guess you can figure it out, I hate city traffic and driving!
Here in New Baden, I will drive 15 miles of country, to go to a WalMart, rather than 16 miles the other way, with a mile of city traffic to go through. One store is (guess) is a little cheaper, bigger inventory, but IMHO a pain to get to.
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
3ft Metal Chevrolet Tailgate (A65583)
3ft Metal...
58in Wagon Wheel Bench (A65583)
58in Wagon Wheel...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2011 Tri Axle Frac Blender Trailer (A64194)
2011 Tri Axle Frac...
2003 Dodge Ram 1500 Pickup Truck (A64194)
2003 Dodge Ram...
