FEL Hydraulic Problem
/ FEL Hydraulic Problem #1
Bill06238
CT
Kubota B7200 HST
I have a 4ft FEL on my Kubota B7200. The boom will not stay up with the bucket loaded or unloaded. I checked the pressure relief valve setting, it was set low and reset it to 1500psi. The bucket still lowers at about 3/4" per minute. I dead headed a pressure gage into a working port on the valve and found that when the valve is opened the pressure is 1450 psi and when the valve is closed the pressure in the line drops down to 0 psi. Could the valve spools be worn to the point that the valve will not hold the pressure? What elese can I check?
/ FEL Hydraulic Problem #2
MY JD drops too. But more like 3 inches per hour under load. I don't get under it.
/ FEL Hydraulic Problem #3
That does sound excessive. If you're not seeing any fluid leaking it could be the piston packing leaking by or as you mentioned, the valving. You might try Kubotas site to see if there's anything listed as to acceptable drop. If not, ask your dealer they should know.
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
John Deere 4044M (A60462)
John Deere 4044M...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
