FEL hydr. adjustment
/ FEL hydr. adjustment
Nice set-up, i've got to find some cutting/digging teeth for bucket also. Thanks for the link.
I've found some on the internet, but they seem to be the HeavyDuty ones. I will mic/meas. my bucket thickness, to put the bolt-on type on(but weld them. Ken, on your grappler build i see you have the size that i am looking for. Where did you find yours, and what size are they 2"x 4.5"? Thanks Jim
/ FEL hydr. adjustment #33
If you are talking about the tooth bar,,I had Fredricks order it when they installed the loader... It just slides in ,and blots to the sides of the bucket..Remove 2 bolts, and it slides right off... I take mine off sometimes ,depending on the work I'm doing
O i see it now, about how far are they spaced? Around 8" looks like from pics. Thanx
/ FEL hydr. adjustment #35
Not sure how far they are spaced.. I can get a measurement if you need it,but I think it's pretty much a standard
Ok, i'll check Fredricks. Thanx a bunch
I have the Prince LVR1GB5AB6(2-spool,14 gpm,open center)Valve for loader. Surplus Ctr. has the Prince MB Series (item# 9-7860) compact 8 gpm, Open ctr. convertible to PB or closed ctr. will this be a good choice for the grappler? I can return from that to the 3pt. Also, found a 5pc. set of weld-on teeth (Ebay) from Titan Attachments in Tenn. for $80 shipped, thinking about ordering and adding to flat bar for 48" bucket. Any feed back, thanks Jim
/ FEL hydr. adjustment #39
looks like the same valve I used.. different ## You can buy it here Prince MB11B5C1 Directional Control Valve Monoblock Cast Iron 1 Spool 4 3 8 | eBay for $7.00 more dollars and get shipping included
I can't answer your tooth bar question.. these Heavy Duty Weld on Bucket Tooth Bucket Teeth Toothbar Tooth Tooth Bar Teeth | eBay are used on my tooth bar
Do you intend to use a bucket grapple /thumb like I installed ? If so, You'll need to reinforce the top & back of your bucket.. If not,,The clamping force will bend the top & back your bucket
Yes Sir, on the reinforcement top/btm.. The teeth i am looking at are heat treated and tempered steel. JD style weld-on adapter, teeth and adapter are 12"long fits most bucket lips up 1.5" thick. The ideals a man can get from this site, is unlimited. Going to use bucket w/teeth around here to get land level and such, while attempting to make the Grappler attachment in spare time. Trying to get all info. i can, your ideal i like. Trying to save all the directions from your build to build one similar, not too heavy and strong. The teeth,adapter,pin alone weigh 35.5 lbs. Hope you don't mind. Thanks Jim.
2020 DRAGON ESP...
2017 Genie GTH-5519 (A53317)
2017 Genie...
KSI Conveyor (A61307)
2011 Ford E-350 Cargo Van (A59230)
2011 Ford E-350...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
