Bucket Hooks FEL hooks
   / FEL hooks #11
GlueGuy
I posted a picture of my hooks back in December. Check this <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=custom&Number=33466&Search=true&Forum=All_Forums&Words=%20hooks&Match=Entire%20Phrase&Searchpage=7&Limit=50&Old=allposts&Main=33417>LINK</A> to that post. There are other posts in the same thread that have some good information too.
   / FEL hooks
I like the hook attachment method shown on ronjhall's link. This arrangement may give me more flexability. Is that a piece of angle iron you welded to the bucket or is it built that way from the factory? John.
   / FEL hooks #13
John
I welded the brackets to the angle iron. Then welded it to the bucket. This idea was not mine. My dealer showed me a tractor he had put hooks on that way for a customer.
If you make something similar to mine, be sure to put some type of reinforcement on the upper edge of bucket. I bent mine. /w3tcompact/icons/frown.gif Then I reinforced it with a piece of 1" heavy wall tubing.
   / FEL hooks #14
Ron,
Yep, that looks like the one I remember. Looks like a real versatile arrangement.
I just got my first welder, and this will be one of the first things I tackle with it. Just as soon as I have a couple of lessons with the welder. /w3tcompact/icons/smile.gif
   / FEL hooks #15
Ron,
How about a pic with the tubing reinforcement?
Thanks!
   / FEL hooks #16
I just fired up my arc welder after 15 year of idle. Burned several holes before finally getting the voltage right. What type of welder did you get?
   / FEL hooks #17
MossRoad; don't worry about it, i burn holes all the time. hope u got some new rods after 15 years of sitting idle/w3tcompact/icons/grin.gif
   / FEL hooks #18
The old rods were pretty soggy, so I bought a new small pack. I'll keep them dry in the basement this time/w3tcompact/icons/tongue.gif
   / FEL hooks #19
It's a Miller AC/DC arc welder; 300 amp capacity, & will run 240 amps with 100% duty cycle. Got it from a guy that learned on it. It ought to be perfect for the kind of "hobby welding" that I plan on doing.
   / FEL hooks #20
<font color=blue>I just got my first welder</font color=blue>
Man, GlueGuy! You're coming up with more and more reasons why I should swing on by one of these days.
I might have to get back into scuba diving just so's I have a reason to head down your way. /w3tcompact/icons/laugh.gif
Toyota LPG 7FGCU20 3,400 Lb. Forklift, S/N 86163, Dual Mast, Tilt, 19,871 Hours Indicated, Asset#... (A59076)
Toyota LPG 7FGCU20...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
utv cart Honda (A56857)
utv cart Honda...
Hydraulic Breaker (A55973)
Hydraulic Breaker...
2003 Big Tex 10PI...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
