FEL for an Iseki TA262
   / FEL for an Iseki TA262 #1
rstone
Detroit,Alabama
Mahindra 3616
I am looking for a FEL that will bolt up to my Iseki TA 262 and also how to tap into the hydraulics
   / FEL for an Iseki TA262 #2
Look under Koyker MFR web site for a dealer close to you. Once you get to the Koyker web site, select dealer location, put in your zip code and will list dealer close to you. Not sure if Koyker makes a FEL for the 262 but there is probably something that will work. Prices go up on 1 April 2008.
DragStripper1
Wisconsin
   / FEL for an Iseki TA262 #3
I put a Great Bend/Bush Hog loader on a TA270. They don't support the Greys as well as Koyker. I had to get one for a Massey 1250. I liked it because it was a model that mounted at the rear and didn't have to attach at the front bumper. They even have a grill guard you can use with it. It also has a really nice hydraulic connect that you don't have to cut pipes and splice in.
   / FEL for an Iseki TA262 #4
I bought a Koyker 125 from Len on here to put on my TA247. The 125 covers up to the 262 but would only have a 48" bucket. Very easy to install and no pipes to cut. The koyker has a pump adaptor that is easy to install as well. It seems to be a good FEL and I use it extensivly..
MM.
yomax4,
why do i need a pump adapter? is it used to keep myou from having to cut the hyd. pipes?
   / FEL for an Iseki TA262 #6
There is a block under your right foot. It has a hydraulic line going in and one out to the rear. The adapter is a replacement for that. It saves cutting the lines. It is very simple to do and almost foolproof. The compression adapters used when cutting in sometimes aren't a perfect fit.
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2012 PETERBILT 365(INOPERABLE) (A52472)
2012 PETERBILT...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
2014 JOHN DEERE 4066R LOT NUMBER 23 (A53084)
2014 JOHN DEERE...
