FEL float position stuck.
   / FEL float position stuck. #1
wedge40
Veteran Member
Not sure if this should be here or in the hydraulics section. I read on TBN about the float position and decided to see if I had one and if so try it out. Well I do have one and it seems to work pretty good. Too good because now it's stuck in the float position. I can raise and lower the FEL like normal but now I can't get any down pressure to apply. It will only do float. I'm guessing something got stuck when I used it. Any suggestion as how to fix this? I'm not keen on taking the valve off, but if that's the only way I will.
In case you're wondering it's a Koyker 210 loader, thats about 5 years old.
Wedge
   / FEL float position stuck. #2
Sounds like your linkage is dry and stuck, you need to lube the balls in the detent cap.
FEL float UN-STUCK. :D Once in float mode I have to wait a while when just using down pressure for it to go back to normal.
Wedge
20 ft. Shipping Container (A53117)
20 ft. Shipping...
40' shipping container (A52377)
40' shipping...
Light Tower (A52377)
Kubota RTV500 (A47384)
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
