FEL edge mods using a pipe?
   / FEL edge mods using a pipe? #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I've seen a few posts about cutting a pipe and putting it on the front of a FEL. Does anyone have any pictures and is the supposed to make it less likely you'll dig up blacktop or concrete when you plow with it. THanks.
   / FEL edge mods using a pipe? #2
Another interesting option that someone posted some pictures of in the past was bolting on a pair of wood runners, made from 2x6 or something similar, to the bucket sides.
These held the bucket off the FLAT, or slightly crowned, pavement a bit, and seemed like they might be a good option and easy to replace or lower (by drilling new hole in the wood) as they wore away.
Sorry, don't have any pictures of either idea though... /forums/images/graemlins/crazy.gif
   / FEL edge mods using a pipe? #3
Think it was on the Gravely forum that a Gravely guy put some PVC pipe along the bottom of his snow plow.
I have some plain heater hose around the top edges of the hopper on my Troy Bilt (got tired of getting my arms bruised from stuff being jerked towards the hopper with my arm attached). All I did was cut down one side of the heater hose with some scissor type tin snips and slipped it over the edges. Used some silicone (Goop) sealant to keep it in place.
Wonder if this would work on the edge of the bucket? Guess main question would be how long will it last? Think the PVC pipe lasted the guy through 7 plowings of driveways.
Ralph
   / FEL edge mods using a pipe? #4
I put a 2x12 four foot board UNDER the front lip of my FEL. Had it sticking out about 2".
It wears out on concrete pretty quickly, but you don't scar the concrete.
Sorry, can't find my pic of it.
ron
   / FEL edge mods using a pipe? #5
I have seen the pics but do not remember who posted them. Try a search for snow & pipe or something similar. I also use wood under the front of the FEL bucket. I was concerned with scuffing and marking the concrete and asphalt during plowing and scraping packed snow. I beveled the edge of a 2x6 at about 30 deg. and mounted it under the bucket cutting edge. It has worked well and is wearing OK. If I get a winter with just turning it around I will be satisfied.
As far as the PVC pipe I also tried this (I though it was an original idea). I slit a 4" PVC pipe and slid it over the bottom of my rear blade. It lasted 4 passes on my 950' gravel portion of my drive. It shattered in the middle while plowing at 10 deg. F. Not very good wear.
WHat about using a steel pipe. Alot stronger and it still would protect the driveway. You could bolt it on and off too or just tack weld it on too.
   / FEL edge mods using a pipe? #8
Matt,
Before I added the wood on the FEL I had angle iron in the same location on the FEL as the wood. It scrated the pavement up pretty good. I would think pipe would do the same.
Doesn't the wood self destruct on the driveway? I thought the round pipe would make it less likely to catch but I never thought it would still scratch the blacktop too.
I wonder is a chunk of industrial plastic would work and last longer than wood.
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2026 Hillcrest Dump Trailer (A56858)
2026 Hillcrest...
2015 Nissan Pathfinder 4WD SUV (A56859)
2015 Nissan...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
1987 Ford F800 E-One Pumper Fire Truck (A55852)
1987 Ford F800...
CFG Industrail MX15RX (A56469)
CFG Industrail...
