FEL cylinders bleeding off
   / FEL cylinders bleeding off #1
KYMike
Central Kentucky
Branson 3510
On my Branson 3510 (65 hrs), both the boom and bucket bleed down when parked. Put a couple hundred pounds of gravel in it and measured it over 2 hours. The bucket cylinder gained 1/2 inch and the boom cylinder lost an inch. Never heard it pop or anything, but every 15 minutes I measured both cylinders which steadily bled down. No leaks, fluid level fine, and no "hot hoses." Is this normal? I know it's best to park it with the FEL down, but shouldn't it stay up? No problem, BTW, with the 3PH.
   / FEL cylinders bleeding off #2
That is normal. Some companies publish the allowed leak down rates.
   / FEL cylinders bleeding off #3
Its always good practice to take the stress off the cylinders when not in use,When your parked,put the bucket on the ground,the same goes for a backhoe,Enjoy the new Branson.Good machine
   / FEL cylinders bleeding off #4
</font><font color="blue" class="small">( That is normal. Some companies publish the allowed leak down rates. )</font>
Yah. I think Kubota has told me that about 2' drop per 15 minutes is about normal. /forums/images/graemlins/shocked.gif /forums/images/graemlins/mad.gif
2019 CATERPILLAR 330GC LONG REACH EXCAVATOR (A51246)
2019 CATERPILLAR...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
UNUSED AGT 54" EXCAVATOR HYD BRUSH CUTTER (A51248)
UNUSED AGT 54"...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
1138 (A51247)
1138 (A51247)
