FEL cylinder leak
   / FEL cylinder leak #1
JPB7745
Okatie, SC
Kubota L2501 & Ford 3000
My dealer filed for a warranty claim but tractor FEL was 8 months out of warranty. This is a defective weld weld that drips when a heavy load is lifted. I guess I will remove cylinder and weld it myself.
   / FEL cylinder leak #2
Just grind it a little bit to get fresh metal and give it a tack weld of the pin hole.
Looks like it's in the back of the cylinder, so you may be able to just extend the cylinder and weld in place.
   / FEL cylinder leak
Just what I was thinking too!! Thanks
   / FEL cylinder leak
You need to get the oil out of the crack if you expect to weld it successfully.
Yes I do agree, plan on disconnecting hoses, grinding down a bit and heating up that area with torch to burn off any oil that may be there. Good point.
   / FEL cylinder leak #9
That is so obviously a manufacturing defect I'm surprised Kubota won't cover it. You might try contacting kubota yourself and see if they'll help you.
   / FEL cylinder leak #10
Yeah, you must cook the oil out of the crack first. Then, after welding, do an air test with soapy water to test for leaks. If you don't air test, and you have some more oil leaks, you will have to cook the oil out again. Sometimes, you have to do several air tests and welds. I have done this more than a dozen times. Welding hates oil.
For my air pressure test, I just stick a rubber-tipped air nozzle into the work port with the rod fully extended. I have had pinhole leaks numerous times.
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2023 John Deere 6155M MFWD Tractor (A53342)
2023 John Deere...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
