FEL Cutting Edge
   / FEL Cutting Edge #1
arnoldziffel
Branson 4225h, Mahindra 2516, several Toro Wheel Horse 522xi machines.
I have a new Branson 4225h. I'm just starting to use it and believe it would be wise to install a FEL cutting edge.
I want a good quality cutting edge. I've not yet spoken with my dealer about this.
- Does Branson sell cutting edges specific to their line of tractors? If yes, any experience or opinions on quality and pricing?
- Are good or better cutting edges available from other sources in the marketplace?
Thanks.
   / FEL Cutting Edge #3
My Branson dealer didn't have any specific cutting edges for my 8050 and I didn't get one ordered soon enough for it.
That said mine doesn't have the standard bolt pattern for most cutting edges and with 6-700 hours on it I still need to add one,
I have had to tweak mine back a bit straighter a couple of times.
The easiest to add will be the various weld on cutting edges, I prefer a straight edge over the toothed style edges.
   / FEL Cutting Edge #4
I have an eight tooth - tooth bar from a company called Rankin. It does what I need. I think your best bet - Google - tooth bar and stand back. There are probably hundreds of companies that make all forms of add-on tooth bars. If you look closely - thru the grass & weeds - it's yellow, it's bolted on the lip of the bucket - it has eight large hardened teeth.
   / FEL Cutting Edge
Thanks for the responses so far.
I should have mentioned in my first post that I foresee using the FEL primarily for infrequent snow management and very infrequent sand and run-a-crush movement.
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
2019 ExMark Lazer Z S-Series 72in Zero Turn Mower (A51691)
2019 ExMark Lazer...
2023 John Deere HD50F Draper Head (A53342)
2023 John Deere...
1997 East Manufacturing Walking-Floor Trailer, VIN # 1E1U1X287VRE22897 (A51572)
1997 East...
2023 CIMC 53X102 REEFER TRAILER (A52576)
2023 CIMC 53X102...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
