FEL chain harrow?
   / FEL chain harrow? #1
KevPH
North Coast, Ohio
JD 4115
I'm considering building a FEL/fork mounted chain harrow. I'm leveling #4 & #57 limestone for the driveway. The FEL would raise/ lower the harrow, also possibly add some down pressure weight. Another plus is the operator is looking forward! What problems do I need to consider during the design of the tool?
   / FEL chain harrow? #2
<font color="blue"> What problems do I need to consider during the design of the tool? </font>
First, welcome to TBN, KevPH! /forums/images/graemlins/cool.gif
I assume you are referring to something that looks like this?
1. Making sure it doesn't fall off and get run over. Depending upon how the tines are pointed, this could cause some problems with the tires /forums/images/graemlins/frown.gif
2. I'm not sure how you'd be able to apply down pressure. BTW, my drag harrow does fine without down pressure.
3. If it's too long, or you change the angle of the bucket, the front tires could 'catch' the end of the harrow and nasty things would follow.
Why don't you want to use a drag harrow behind the tractor?
   / FEL chain harrow?
Thanks Mike for your imput! My FEL has a Quich-attach and 42" pallet forks. I need to raise the "chain harrow" (without spikes) and make tight turns. Fabing a slip attach to a set of fork is easy and fast! The loader will lift the chain harrow completely off the ground without a large support frame. Last storing a tool that can fold onto itself would provide a plus to limited shed space. I do agree, over running any tool will cause damage. Thank again Mike!
   / FEL chain harrow? #4
Do you have a boom pole? I use a drag made of two 5' pieces of I-beam, and use tho boom pole to do just as you said. I prefer to drag in the forward direction If you use the bucket and go forward, and the chain unhooks, you'll run over the thing you're dragging. Don't ask how I know............chim
2025 20ft. G70 Cargo Transport Chain (A48081)
2025 20ft. G70...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
Headache Rack (A50860)
2014 Chevrolet Impala Limited Sedan (A48082)
2014 Chevrolet...
2017 Nissan Titan SV Crew Cab Pickup Truck (A48081)
2017 Nissan Titan...
2015 Bandit 990 XP Trailer Mounted Wood Chipper (A50860)
2015 Bandit 990 XP...
