Front-End Loader FEL bucket won't tilt down
   / FEL bucket won't tilt down #11
I had a similar problem but I could not curl my bucket up or down. It turned out that I broke the cable that went from my joystick to the valve. A quick trip to the dealer for a new cable then a few hours of trying the correct combination of adjustments to get it all back together. I had to remove both cables from the joystick to get it back on the central pivot point.
   / FEL bucket won't tilt down #12
My bucket tilt was acting weird a couple weeks ago too.
The quick-connect had come undone at the valve. My curl worked but only the gravity dump would work. If I went over to regen then the bucket would curl again. I thought I blew out some internal seals until I finally noticed the coupler had come undone.
   / FEL bucket won't tilt down #13
Didn't he say the engine was loading down? Bleed some oil out of the line going to the rod end and see if it well drop down then.
   / FEL bucket won't tilt down #14
I also had that problem but my cable was only loose. After 5 minutes of trouble shooting it took 1 minute to repair.
   / FEL bucket won't tilt down #15
Ditto what has been said.
My money is on a coupler. But swapping lift and curl hoses will confirm weather its the valve or hoses.
   / FEL bucket won't tilt down #16
The suggestions the guys have already made are good ones. Reseat every single one of the quick connects. Some may be buried where you have never had them apart before. They also suggested swapping hoses to see if the tilt was really hung up or else the (unlikely) loader valve issue. OK. What dealer mechanics usually do with this sort of problem is insert a set of gauges into the various quick connects and take pressure readings. You might get that diagnostic service done pretty cheaply. Since the loader valve CAN cause such issues, take a look at the small (inch or so diameter) spool end covers on the loader valve. Should find 4, 2 on one end and 2 on the other. Typically they are secured with long 1/8" screws with Allen wrench heads to loosen or tighten. Since the tolerances are so tight on those spools , if any ends are loose that could cause your issue (though not likely.) Control cable connections to the loader valve spool ends are usually threaded and offer adjustment too.I would not dick with those until/unless you have exhausted the connectors for sure. Best of luck and let us know what finally fixed it.
   / FEL bucket won't tilt down #17
Does this have quick connects for the loader (mid point, removable loader? If so, Check to make sure they are all connected properly by disconnecting and reconnecting them. Make sure to turn the machine off and relieve system pressure first.
2 years 8 months after this post.......My LS XG3032 FEL stopped dumping. I spent six hours on the Internet today reading about joysticks, cables and controllers trying to figure out the problem then I ran across this post.
Thanks to this post I remembered two months ago my dealer installed a new clutch in this tractor and had to remove the FEL. I went out to check how cables were disconnected for the removal. Guess what one of the mid point Quick Connectors had disconnected. Bam! Problem solved.
   / FEL bucket won't tilt down #18
   / FEL bucket won't tilt down #19
hey all!I have the same problem on an L4740,checked connectors and hoses,found nothing,resated as well all couplers to no avail,replaced a leaking seal in one cylinder and still wont tilt down hydraulically,getting ready to look closely at the control valve,any suggestions would be appreciated.also the pump labors when down is actuated.
   / FEL bucket won't tilt down #20
Alva
Quick disconnects can fail due to a internal springs getting weak.
Try curling the bucket slightly and then feather the control very slowly try to dump. If you can dump slowly and fails faster one of the quick disconnects is most likely the problem.
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
5' MOWER (A52706)
5' MOWER (A52706)
2021 Troy-Bilt TB110 21in Push Mower (A55973)
2021 Troy-Bilt...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
