Front-End Loader FEL bucket won't tilt down
   / FEL bucket won't tilt down #1
oslaton
Athens, TX
Mahindra 6525
My 2 year old 6525's FEL bucket just instantly stopped being able to tilt down. It is now in the most upward position. It was working just fine and after the last bucket load, it would not tilt. When operating the controls it sounds like it is pressuring up just as it would at any maximum position. I disconnected the bucket from the cylinders but they still would not extend. Joystick seems to be working. Removed boot and all is still new and greased. All other hydraulics work fine. I just can't dump the bucket. Any suggestions?
   / FEL bucket won't tilt down #2
Try disconnecting and reconnecting the quick disconnects in the tilt circuit. Possible of them has been slightly disconnected from a hose being pulled on.
   / FEL bucket won't tilt down #3
Does this have quick connects for the loader (mid point, removable loader? If so, Check to make sure they are all connected properly by disconnecting and reconnecting them. Make sure to turn the machine off and relieve system pressure first.
   / FEL bucket won't tilt down #4
I'm with these guys, a hose coupler has failed or is partially uncoupled.
   / FEL bucket won't tilt down #5
When that happened to us that is exactly what it was ... one of the QD popped lose.
   / FEL bucket won't tilt down #6
Unseated quick connect did that to me, too...
Nick
Thanks for the replies but I have already checked all connections, switched some around trying to identify a bad coupling and even reversed some hoses. It seems that the return line may not be releasing. When I reversed the two bucket lines lines, the problem was it would not tilt back. Opposite of what it did before. That line also held pressure even after killing engine and working joystick to relieve pressure. I do not have much experience with hydraulic control units. How would one check the releasing circuit? If that is what it is called.
   / FEL bucket won't tilt down #8
Not saying it's not your valve..... But that's rare. Usually a coupler.
How about swapping the bucket tilt hoses with the boom lift hoses and see if the problem is still the tilt???
   / FEL bucket won't tilt down #9
If pressure isn't releasing back into the system, it's still likely that the hose cooler is the issue. On that disconnect (the one for the circuit that is apparently malfunctioning) check the coupler itself. I had the issue once and the spring inside the male coupler tip was malfunctioning, and the tip wasn't returning to center. It didn't do it every time, so it was actually tricky to figure out at first. I went to my local dealer and picked up a new coupler, screwed it on, and everything was fixed.
   / FEL bucket won't tilt down #10
Yep. I'm leaning toward coupler. If so, by switching the boom lift and bucket tilt circuits he'll figure that out pretty quick. :)
Year: 2021 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 52,371 Plate: Body Type: 4 (A55852)
Year: 2021 Make...
2012 HEIL CRUDE TRAILER (A55745)
2012 HEIL CRUDE...
2013 Ford Edge (A54815)
2013 Ford Edge...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2012 Chevrolet Silverado 3500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
2016 Ford F-150 4x4 Pickup Truck (A55852)
2016 Ford F-150...
