FEL Bucket Wax
   / FEL Bucket Wax #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
Has anyone heard of a "wax" or similar product that I could coat the inside of my bucket so that when I'm moving snow in the winter, the packed snow doesn't stick to the inside of the bucket causing me to only to get 1/2 scoops ??? I have heard that there is a product available but can't find anything locally.
Eric
   / FEL Bucket Wax #2
Haven't heard of anything marketed like that, but I would think ski wax would fit the bill pretty well. It solves a similar problem.
Cliff
   / FEL Bucket Wax #3
I've heard of people using PAM (the cooking spray), but I had pretty good luck last year just having the bucket the same temp as the (outside, unheated) air. Not 100% successful, mind you, but pretty good.
   / FEL Bucket Wax #4
I just use the cheapest car wax that I can find. Remember to pay special attention to the corners where the end sheet meets the main sheet. Start with a healthy coating there first. Then work on the larger areas.
I don't even wipe the wax off when I'm done coating the inside of the bucket. I figure the more wax the better...besides, who is going to stand out in the cold and criticize your swirl marks?
The combination of the wax and a cold bucket (leave the bucket sit outside while the snow is falling) gives me great success. No sticking!
   / FEL Bucket Wax #5
Eric,
I don't know if it would work on the bucket, but I used this on my 54" mower deck from my 445. My JD dealer had a product that I believe was called Slick Coat. Farmers would use it on various equipment to lubricate and protect. It goes on as a gunmetal gray primer that is very smooth to the touch. I think it actually has Teflon material in the spray/primer.
BTW, I had my new 62" belly mower coated with a smooth Rhino lining. Works great. Wears great. Much easier cleanup.
John
   / FEL Bucket Wax #6
Eric , I use Johnsons paste wax . It holds up fairly well .
And for touch up( or lazziness ) I use PAM spray . John
   / FEL Bucket Wax #7
I would use PAM - it does wonder's on my Satellite dish to keep the wet snow off in the winter. /forums/images/graemlins/wink.gif
-Bob
   / FEL Bucket Wax #8
I use the store brand cooking spray, which is cheaper than PAM. /forums/images/graemlins/cool.gif
   / FEL Bucket Wax #9
The original name and non-JD name for the product is Slip-Plate. Lots of farm stores and TSC sell it in spray cans and also in gallons. It has a high graphite content.
   / FEL Bucket Wax #10
Hi...
Here's a link for Snow Plow Wax...
Can also be used on mower decks...
Haven't used it... so dunno' how effective it is...
A new coat of high gloss paint helps too...
Dave...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
45in Excavator Bucket (A50322)
45in Excavator...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2007 Ford F-150...
2003 Lexus LS 430 Sedan (A50324)
2003 Lexus LS 430...
2013 RAM 4500 (A50323)
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
