FEL BUCKET QUESTION
/ FEL BUCKET QUESTION #1
fih25
central PA
Kubota BX 1500,Cub Cadet LTX 1042
I have had my bx1500 for 2+ years now, My question is regarding the FEL bucket. The leading/cutting edge of the bucket is starting to "rollover" some. What's best way to sharpen it? File it or grind it?
/ FEL BUCKET QUESTION #2
Just use it until it is worn out and then have a new edge installed.
/ FEL BUCKET QUESTION #3
I use a flat bolt-on wear plate and swap that out with a toothbar when needed.
The wear plate gives me an extra 3-4 inches of loader lip capacity which really helps with moving large quantities of light material, such as mulch and dry dirt.
It eliminated wear on the FEL for snow removal.
Thanks for all of your input, however, the leading/cutting edge on my FEL is welded on.
/ FEL BUCKET QUESTION #5
I just cut em out and weld in a new one. Put in a wider one to add more strength to the front. You can buy them in all sizes from a heavy equipment dealer.
/ FEL BUCKET QUESTION #6
I have found that if I keep my bucket as flat as I can while still getting the job done, "rollover" is reduced. Keeping the bucket and edge flat will also lengthen the cutting edge's life because you are spreading the wear over a greater surface area.
In contrast, the more you angle the cutting edge perpendicular to your work, the greater the chance of the cutting edge of curling back at the edge. I have found this to be especially true on pavement.
I agree with the other posters by saying that you should just use the bucket and then have a new edge welded on.
/ FEL BUCKET QUESTION #7
Factory is a weld-on plate on BX series.
I have added a bolt on flat plate (similar to a tooth bar) that is readily available. This will protect the factory edge, give you extra capacity, and easily be replaced. Why bother with a new weld-on?
/ FEL BUCKET QUESTION #8
I had to replace the welded on cutting edge on my B7100 tractor. It was replaced with a much heavier one that I doubt I will ever be able to wear out. It has also really helped stiffen up the bucket.:)
For the smaller tractors I'd recommend a heavier cutting edge and also cutting edge welded to both sides of the bucket. Make for a very stiff bucket that should not develope a grin as some do.:)
