Snow FEL bucket plus Back Blade?
/ FEL bucket plus Back Blade? #1
PJL13
Upstate, NY
LS XJ2025H
I am in the process of getting an XJ2025 and have started to think about snow removal of my 250 ft long gravel driveway, even though it is only June. A friend suggested floating the FEL bucket a couple of inches and get a somewhat cheap forward facing back blade to "scrape" whatever is left behind by the FEL bucket. I just wanted to see what others have done or think about this suggestion. I am not handy enough to weld or modify any attachments, so trying to find/plan for the simplest solution. Thank you for input!
/ FEL bucket plus Back Blade? #2
If you want to use the bucket, do a search for the "edge tamer" by R2 Manufacturing. But, you'll also be able to do it by just turning the back blade around and scraping.
/ FEL bucket plus Back Blade? #3
That good setup long as you don't get lot of snow.
Pushing snow w/rear blade okay long as your gentle,for scrape blade really made to pull.
You may want to consider front blade of sort that swing to L&R either by hyd. or manual...cold w/howling winds in open cab 250' driveway can seem mighty long.
/ FEL bucket plus Back Blade? #4
I don't know SQUAT about shoveling snow, but I do know that "keeping warm" is possible even when subjected to extreme cold (here that is 25-40 degrees)
Electric clothing seems to work on a motorcycle, seems like it ought to work on a tractor, just saying...I have Gerbing coat, pants and gloves that I wear on my motorcycle. Keeps me warm, and I don't do a lot of layering, or a coat over it. Before electric clothing years ago, I drove a forklift outdoors alot, and took a small heater core, built a wooden box around it and put a 12 volt fan in it. Piped it into the forklift hoses that warmed the propane regulator and I had heat at my feet. Amazing what you can figure out to do when your cold!
I would, as was suggested, that you seriously consider not using a rear blade in reverse, as bending the lower lift arms is expensive (been there, done that)
David from jax
OK, I think maybe I got my terms mixed up. Sounds like if I get a grader/scrape blade (such as the one here: 6' Heavy Duty Rear Blade scraper blade ) opposed to a rear blade, that I can use the FEL bucket to push the snow in front of me, while also dragging the blade on my 3 pt hitch to "clean up" whatever I am not pushing with the bucket during each pass. Does that sound about right?
/ FEL bucket plus Back Blade? #6
You will soon hate doing snow removal with just the FEL;definately get a rear blade wider than your rear wheels when the blade is angled.
/ FEL bucket plus Back Blade? #7
Times 2. I would recommend a 6' rear blade as a 5' blade will barely extend wider than your rear wheels when angled. If the snow is less than 6" deep, no need to lower the bucket - just plow away pulling the angled rear blade.
A rear blade is relatively inexpensive and versatile for a number of uses.
/ FEL bucket plus Back Blade? #8
I have tried about every way shape and form trying to find the best setup for removing snow, my 48 inch OEM bucket was just about worthless with a storm of 12 inchs never mind our normal 20 inch storms, I bought a bigger bucket "60"inch and a back blade, tried that last year on my 300ft driveway, didn't like the results of that setup, I am convinced at this point that my bigger bucket and a 54 inch Blizzard 3ph snowblower is the answer for me, I bought a new one three weeks ago, I have a backup camera and I don't mind turning in the seat to see what's going on, I would rather turn sideways to see snow blowing 30-40ft than sit on a tractor for hours on end bucketing snow, the way I see it is I will be inside near the wood stove drinking coffee in better than 1/2 the time it takes with a bucket and blade on the back.
/ FEL bucket plus Back Blade? #9
I have a mile long gravel driveway that I plow the snow with my rear blade. When I had a smaller tractor I also used a PTO snow blower to clear the berms that would develop. With my larger Kubota there is no need for the snow blower - the tractor with rear blade is heavy enough to keep the berms cleared.
If I have to move snow from some weird location - I will use the bucket on the FEL rather than pushing with the rear blade. I don't want to hit a "frozen something" and damage the 3-point system.
The rear tires on the tractor are 80" - outside to outside. The rear blade is an 8 foot Rhino 950. Even with a 96" rear blade, the offset and angle will not completely cover the 80" rear tire width. Its close enough - unless we get a really deep snow, two passes will clear the driveway.
My advantage in plowing with the rear blade is total tractor weight - with rear blade and grapple it weighs 10,050#. Even the tallest berms that can form down the driveway don't push the tractor around.
/ FEL bucket plus Back Blade? #10
I have a mile long gravel driveway that I plow the snow with my rear blade. When I had a smaller tractor I also used a PTO snow blower to clear the berms that would develop. With my larger Kubota there is no need for the snow blower - the tractor with rear blade are heavy enough to keep the berms cleared.
oosik
How does your experience with a 5 ton tractor set up help the OP with his 1 ton XJ2025?
Just curious as to the connection. I don't seem to see any.
/ FEL bucket plus Back Blade? #11
I hate to say it but other than a snowblower I dont see any real way to clear a long driveway with a little tractor like ours.
Ive got a 1200' driveway and living in northern NH we get quite a bit of snow...the tractor with FEL is perfect for cleaning up and helping push back piles, but it would never be practical to clear my whole driveway with it. If you float the bucket and drive forward you wont get very far before the pile of snow is big enough to stop the tractor and you'll have to lift it, and drive over snow to go dump it, then come back and do that again, etc...obviously it could be done but there are better ways.
Maybe some sorta plow setup but even that I dont think would work great. I plow my driveway and I have to angle the plow and build up some speed to help throw the snow off the side a bit. And often I push into piles pretty hard to push them back and make more room for future snow. The 2025 just isnt heavy enough to really push back piles like that with a plow.
I'd say a rear mount snowblower would be your best option. If you've got a gravel driveway like I do just drive on the first few snowfalls and pack it down into a nice dense base before plowing or snowblowing, that way you arent picking up gravel with the blower.
I know this is way off topic from what you originally asked...but for the price of a snowblower you can find some beater yard truck with a plow on it and run that to clear the majority of the snow, then use your FEL for cleanup. I've had a mid-90s reg cab Chevy with plow I picked up for $1200 going on 4 years now...if I paid someone to plow my driveway I wouldnt doubt I'd be looking at $1000/season at least anyway so I figure its more than paid for itself and will hopefully keep going for many more years!
/ FEL bucket plus Back Blade? #12
Blstr88 - That is a reasonable response.
PJL13 - How is the snow cleared from your driveway now?
Is it flat or sloped?
What is the typical depth of snowfall you will be clearing?
What is the maximum depth of snowfall you will be clearing?
R1, R4 or turf tires on your new tractor?
/ FEL bucket plus Back Blade? #13
With an "UpState NY" address, snow could be from a dusting to over two feet.. The bigger falls often mean getting out there and chiseling away at some of it mid storm, regardless of equipment options.
/ FEL bucket plus Back Blade? #14
My blizzard blower has a 28 inch tall inlet, sometimes I can't get out there mid storm because it is literally a Blizzard so when I get a couple of feet I will take it slow. We get three storms a week here, the guy down the road blows snow with his kubota we have about the same driveway setup, he is done with a two storm at least an hour before I'm done screwing around trying to bucket it and back blading, small tractor a snowblower and a bucket on the other end is my recommendation.
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
Bull Skull (A61569)
Bull Skull (A61569)
Set 4 - 10-16.5 tires on wheels for bobcat (A61567)
Set 4 - 10-16.5...
New/Unused Two Wheeled Electric Bike (A61166)
New/Unused Two...
