FEL broken pin stuck
   / FEL broken pin stuck #1
Diwali
Bronze Member
Isle of Anglesey, Wales, UK
Case IH 248 and Craftsman LT2000
I have a McConnel FEL on my CaseIH tractor and discovered a crack in the steelwork of the headframe (that supports the quick release bucket). I have removed the headframe by taking out the two pins (approx. 1 1/2" diameter) that attach it to the the arms of the FEL. One came out easily enough but the right side pin had split inside its housing exactly where the dowel roll pin fitted. With a bit of effort the top part of the pin came out leaving the other end stuck in position. Now I have a problem; the stuck pin will not shift at all. It's 2-3" long and about 1 1/2" diameter and seems to have corroded inside the housing. Any ideas on how to remove? If I can't remove it there is no point in repairing the crack in the steel and I will have to buy a new headframe! Help!
   / FEL broken pin stuck #2
Can you post picture or two?
   / FEL broken pin stuck #3
Hire a welder with a rosebud torch or use a can of mapp gas and a torch
and heat up the outer mounting to loosen up the pin and use a 4 pound
hammer and a piece of round stock the diameter of the pin to drive it out.
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
100' Roll of new 5/8"/16mm Crane Cable  (A52384)
100' Roll of new...
2019 TAKEUCHI TL6R SKID STEER (A51246)
2019 TAKEUCHI TL6R...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
