fel bleeding down in dump position
/ fel bleeding down in dump position #1
jinmared
Goldendale,Wa
Jinma 354 fwd
My FEL bleeds down in the dump position when it is not being used. I have tightened all the fittings and cannot find any leaks. The fluid level in the tank is ok. Any ideas anyone?
The unit works ok otherwise
/ fel bleeding down in dump position #2
One of the bucket dump cylinders is probably allowing fluid leak around the piston packing. It will need to be repaired or replaced. Or it could be the spool valve. How old is the loader ? If under warranty check with your dealer a certain amount of leakby in the cylinders is "normal" per most dealers.
Ben
/ fel bleeding down in dump position #3
Leak down is a normal situation. It will depend on the speed of leak, whether it should have anything done to it or not.
/ fel bleeding down in dump position #4
In one of the grapple threads Pineridge discussed double piloted check valves. This will keep the cylinders from leaking down through the valves.
/ fel bleeding down in dump position #5
A quick way to isolate the condition is to switch hoses from the bucket cylinders to the hoses for the lift cylinders. If the bucket still settles after switching hoses, the bucket cylinders are at fault and will have to be rebuilt. If the lift cylinders settle, the valve will be the culprit and will have to be rebuilt. Hope this helps. /forums/images/graemlins/smile.gif
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
2018 Ford AWD Explorer SUV (A61569)
2018 Ford AWD...
Toro Timecutter Max (A61166)
Toro Timecutter...
UNUSED KJ 45'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 45'X25'...
DEERE CLIMBER (A62131)
1995 Crosley 20ft. 3 Ton T/A Equipment Trailer (A61568)
1995 Crosley 20ft...
