FEL Bale Spear
/ FEL Bale Spear #1
West Point, Tx.
Mahindra 6000
My dealer told me that they make bale spears that will attach to the bucket, but that he would avoid them, because if you lift a heavy bale, it could bend the bucket. I would like to ask you experts what yall think about that. The dealer recommends a bale spear that requires unmounting the bucket and then mounting the spear to the arms of the ML260 FEL.
WHich way should I go ?
Charlie
/ FEL Bale Spear #2
I'd listen to him. Not only could you damage the bucket, but using this type of setup will reduce your lift and roll back capacities a great deal. The further out from the pivot point the more force that will be required. If it is a KMW ML260, there are both skid steer and pin on type quick attaches available. These both make for an easy transition from bale spear to bucket and back. /forums/images/graemlins/smile.gif
/ FEL Bale Spear #3
I produce approx. 250 tons of hay per year and we use our 4110 to move it all. I opted for the ATI Tach All which replaced the stock bucket (which in my opinion is not worth a ****). I agree with the dealer as the stock bucket is not worth the metal it is made from and the bolt-on bale spear will only exacerbate the stock bucket's intolerances. For instance, I bent the stock bucket beyond repair within a few months of use.
Regardless, I bought a used, quick attach JCB bucket from HOLT machinery's rental line for approx. $150. The bucket was in excellent condition and came with removable teeth. More to the point, I purchased a new, quick attach bale spear (as I could not locate a used one) for moving my round bales (approx. weight is 1,200 lbs.). It is tough, heavy duty and ideal. It cost approx. $500.
I have to write that I will never own another tractor without a quick attach on the FEL like the ATI Tach All.
If you will moving many bales, then I would not purchase the bolt-on bucket style. However, if you move two to ten bales a year, then I would improvise and make do with them.
Hope this helps.
/ FEL Bale Spear #4
Charliechan:
I'm not familiar with a Mahindra bucket, but I agree with the other posters. I do use a bucket spear with my 5030HSTC Kubota in our commercial operation. I handle upward of 400 rounds per year X 2. The only way I'd use a bucket spear is with an excavation type bucket. A material bucket will flex and break in the corners. You put a tremendous strain on the bottom lip of the bucket every time you lift a bale and that strain is concentrated in a small area, right in the center of the bucket, right at it's weakest point. I also agree that a Bobcat style quick attach is the only way to go. I have pallet forks, etc. and the quick attach makes it easy to change implements.
/ FEL Bale Spear #5
I got the 6000 with the QA Plate and a bale spear and I'm glad i did. I can be from bucket to spear to bucket in no time. I don't know how anyone could make a stronger bucket than Mahindra. I've used mine for everything from digging up stumps and grading driveways to pounding in posts and it's held up wonderfully. I chose the QA options for convenience.
Towable Road Crossing / Pipe Bridge Trailer (A63689)
Towable Road...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
2023 Bobcat T770 (A64126)
2023 Bobcat T770...
