FEL arms won't go down when cold
   / FEL arms won't go down when cold #1
barfdog
Suburban west side of Yakima, Texas
I am having an issue with a Kubota B2400 with an LA351 loader. Lately, when I start it up, the FEL arms will go up but don't go down. It starts squealing when I try to lower the arms.
Here are the symptoms:
1) Cold - arms won't go down, squeals when you try, other FEL functions work
2) Cold - if you simultaneously tilt the bucket up or down, you can lower the arms
3) Warm - seems to work fine.
I am a hydraulic idiot, thanks for any advice.
   / FEL arms won't go down when cold #2
Unplug and re-seat the QD's.
Perhaps you have some water in the fluid and it is freezing.
What color is the fluid?
Maybe try a thinner fluid or a fluid made for your climate.
J_J, thanks for the info, I haven't been on the tractor until today. I tried what you suggested, but that didn't work. I then realized that it had nothing to do with the cold, but wasn't working when the 3 point hitch was up. The 3 point hitch was making the squealing noise when it was all the way up. I adjusted the stop nut on the three point hitch lever so it wouldn't go as far. That solved the problem. The nut must have loosened up and was causing the 3 point lever to go too far.
Thanks for your help.
   / FEL arms won't go down when cold #4
Your 3pt was probably in relief, and that will cause problems with the loader.
If you put a gage in the hyd circuit, you will know when and how much pressure and whether there is no pressure so the loader will work normally.
   / FEL arms won't go down when cold #5
Glad you found the trouble.....very common problem
Brent 420 Grain Cart (A53473)
Brent 420 Grain...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
1999 WABASH 48X102 FLATBED TRAILER (A53843)
1999 WABASH 48X102...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
