FEL arms won't go down when cold
   / FEL arms won't go down when cold #1
barfdog
Suburban west side of Yakima, Texas
I am having an issue with a Kubota B2400 with an LA351 loader. Lately, when I start it up, the FEL arms will go up but don't go down. It starts squealing when I try to lower the arms.
Here are the symptoms:
1) Cold - arms won't go down, squeals when you try, other FEL functions work
2) Cold - if you simultaneously tilt the bucket up or down, you can lower the arms
3) Warm - seems to work fine.
I am a hydraulic idiot, thanks for any advice.
   / FEL arms won't go down when cold #2
Unplug and re-seat the QD's.
Perhaps you have some water in the fluid and it is freezing.
What color is the fluid?
Maybe try a thinner fluid or a fluid made for your climate.
J_J, thanks for the info, I haven't been on the tractor until today. I tried what you suggested, but that didn't work. I then realized that it had nothing to do with the cold, but wasn't working when the 3 point hitch was up. The 3 point hitch was making the squealing noise when it was all the way up. I adjusted the stop nut on the three point hitch lever so it wouldn't go as far. That solved the problem. The nut must have loosened up and was causing the 3 point lever to go too far.
Thanks for your help.
   / FEL arms won't go down when cold #4
Your 3pt was probably in relief, and that will cause problems with the loader.
If you put a gage in the hyd circuit, you will know when and how much pressure and whether there is no pressure so the loader will work normally.
   / FEL arms won't go down when cold #5
Glad you found the trouble.....very common problem
Sakai SW880-1 (A47477)
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A53473)
2015 Ford F550...
