FEL and 4WD - How necessary?
   / FEL and 4WD - How necessary? #31
Ah. Thanks.
   / FEL and 4WD - How necessary? #32
You'll find the FEL worth more than it's weight in the end.
Will you use it all the time or for everything? No. But you'll wish far too many times you had one if you don't have it. It's a huge, huge labor saving tool.
Likewise I wouldn't do without 4 wheel.
Back in the, ahem good old days, the ranch's four wheel drive was called 'the Cat'. Uh, short for Caterpillar, a cute little monster of a six cyl. attached to a pair of 12 or 14 foot print cleated tracks.
We did everything by hand that a FEL could've done in less than half the time.
And 4 wheel drive many times would have saved us from walking back to the other end of the ranch to fire up the Cat.
4 wheel drive is no longer exotic and FEL's are reasonably priced.
Don't settle for less.
   / FEL and 4WD - How necessary? #33
I've been moving a lot of boulders that the FEL can't pick up, but I can get under. I have to use 4 wheel drive to have enough traction to move some of them as the weight shifts to the front instead of the back.
   / FEL and 4WD - How necessary? #34
Yes and yes. The FEL is very important, and I would have already been stuck numerous times on my property without 4WD. I would consider both to be required items in any new tractor purchase.
   / FEL and 4WD - How necessary? #35
Even with 4WD you can get stuck that is when you use the FEL to help you get unstuck by picking the front of your tractor up and pushing it back out of the stuck ruts.
   / FEL and 4WD - How necessary? #36
IMHO 4X4 is a must with the work that you are doing.FEL sure comes in handy unless you want to break your back.
   / FEL and 4WD - How necessary? #37
Didn't see it mentioned -but if you heat with firewood, the advantages offered by a loader equipped 4x4 tractor are numerous... especially if you add a grapple
just more reasons to get both tractor options
Good Luck in your search
   / FEL and 4WD - How necessary? #38
It sounds as if most of the responses here advocate using the 4WD in unison with the FEL for digging, hauling loaded buckets, pushing and making sharp turns.
Is there any caution advised for doing damage to the 4 WD system, used in this manner?
Wow! Thanks for the responses guys! I can safely say that I will be holding out for FEL AND 4WD. I think I knew this already, but your responses leave no doubt. The search continues....
   / FEL and 4WD - How necessary? #40
That a boy! You will not be sorry!!! :thumbsup:
ELECTRIC GOLF CART (A58216)
ELECTRIC GOLF CART...
2018 Chevrolet Silverado 2500HD Crew Cab Service Truck (A56858)
2018 Chevrolet...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2012 SOUTHERN VAC 130 BBL STEEL VACUUM TRAILER (A58214)
2012 SOUTHERN VAC...
2326 (A58376)
2326 (A58376)
Set of Heavy Duty Steel Trailer Ramps, 60" Long (A59076)
Set of Heavy Duty...
