FEL 3110D
   / FEL 3110D #1
Gizmo36
Platinum Member
East of Duewest S.C.
Any one have a front end loader on there 3110. If so has any one ever tried to pick up round bells with it. I am thinking of putting a front end loader on .Danny has a good price on them.
   / FEL 3110D #2
Gizmo you are so funny. :D it is funny how our fingers and our minds do not cooperate sometimes and it is not flagged because it IS a word, just not what he wanted!!:eek:
He meant, I believe, whether the fel could pick up round BALES.
Mike:D :D
   / FEL 3110D #3
500 lb bales would be OK. 1000 lb would be questionable. Especially if moving them very far.
   / FEL 3110D #4
I have a Koyker 160 on the front of my YM 3000, the same FEL that is sized to your 3110. I've lifted 1200lbs. with the front end blocked, but a lift over 1000 lbs. would be something you wouldn't want to drive the tractor with. You have a little more weight than I do, but the weak link here seams to be the tires. Tires flaten out ( with 35 psi ) with that much weight. Load I lifted off a pick up, had to block the front end of the tractor, lift, and drive the truck from under the load, move load directly to the ground. They make a "bale spear" for the 3 point for this job but you might have to much weight on the 3 point with a 1000 lb. round bale. Odds are if you want to lift 1 bale, you most likely want to do this regularly. If that is the case, think you should look for a larger machine or use smaller bales. Not worth takeing the chance.
Chris
   / FEL 3110D #5
I have a YM330d with a loader that we use for round bales on the 3 point. It can handle a 1000 bale pretty well. If the bale is much heavier, I have to put extra weight in the bucket.
   / FEL 3110D
The MF 283 burns so much fuel . I try to use the smallest tractor I can for the job. Last year I got diesel fuel at 172 for off road . now it is over 3.00 $ a gal. with diesel and Fertilizer I will have more in hay then I can make off it.
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A53473)
2015 Ford F550...
aerator (A52377)
aerator (A52377)
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
FUEL TANK/TOOLBOX COMBO (A53843)
FUEL TANK/TOOLBOX...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A53843)
2021 ALLMAND BROS...
1996 International Water Truck with a Caterpillar Engine (A53473)
1996 International...
