FDR 1672 blade replacement
/ FDR 1672 blade replacement #1
johnnylight
upstate, New York
TC34DA
Land Pride cost $34.95ea for the mulching blade part # 890-698c
Can I do better?
I tried google for the part and of course it shows land pride
What do you guys use?
is there any cross ref# for 3 party like tractor supply or should I just stick with land pride?
/ FDR 1672 blade replacement #2
I have the FDR2572 finish mower. I was quoted 23.94 each for the 890-318C medium lift blades from the dealer. I believe your manual (or parts manual found at landpride.com) will show low lift, medium lift, and high lift options. I could not find an exact match for the medium lift blades but found some for the high lift blades and the gator mulching blades. I do not want high lift blades as I live in a very sandy area. I am considering the gator blades however. Anyway, look in the manual or parts manual for the different blade numbers and then do a search for each option. Good luck.
