Favorite chain suppliers?
   / Favorite chain suppliers? #1
petebert
Outside of Ann Arbor
Need some chains for a 14.9-24 tire. Finally getting tired of this.
Figure chains would make a huge difference. Any particular supplier you like more than the other? I'm in a pretty decent agricultural area and thought about seeing if anyone local had them. Aside from that I seem to end up on tirechains.com every year via google. Anywhere else I should check out?
   / Favorite chain suppliers? #2
You already found the place I'd recommend. The problem with the desire to "buy local" is the response you typically get is "We have them at the distribution center in Indianapolis, and we can have them here tomorrow." Might not be a big deal for tire chains but when you go to your local bearing supply house for some JD 260 mower spindle bearings and they don't have them on the shelf, it gets to be a pain.
I have abandoned the self-righteous mantra of "Buy local." If you can't find it on-line then your chances of finding it locally at a price you can afford are very very slim.
By the way, go for the Duo-Grip Combos!
   / Favorite chain suppliers? #3
I bought my tractor chains at a local tire distributor - Les Schwab Tires. Got a great deal on some really HD chains - don't know if this dealer goes as far east as you are.
   / Favorite chain suppliers? #4
Check your local tractor supply store. I was in my local TSC a few years ago and found chains on a shelf in the back of the store covered in dust. I asked about them and the manager sold them to me at a closeout price because they had been there so long.
   / Favorite chain suppliers? #5
Looks like some rear ballast is needed as bad as chains!
You should see me with a round bale on the front! Yes some weight on the rear would be great. The tires are full of fluid. I thought about attaching the PTO tiller all winter just for the weight.
   / Favorite chain suppliers? #7
Yes sir. What this guy said.
Tire Chains-Duo Ladder-Tractor
   / Favorite chain suppliers? #8
I found a local dealer for mine, but they seem to come and go. I use the euro studded chains they are more expensive but they work so much better then any other style. IH 574 chains.jpg Branson chains.jpg
The traction and ride quality is amazing, they are the best you can get for a tractor unless you are strictly going into the woods and use skidder ring type.
The duo grip type are almost as poor riding as the old double ring type every time that top link hits hard ground it is link running over a bump, so it's bumpity bump all the time.
   / Favorite chain suppliers? #10
The euro style, the lower ones on the page do not need tensioners the instructions with mine wanted them to be able to move about some on the tire, they are the only ones I haven't used tensioners on. As far as installing the chains the easiest method I have found is as follows;
1) lay the chains out on the ground, studs or outside up, behind the tire,
2) attach a rope (small, baler twine or under a 1/4 inch) to the chain ends (inner on euro) to make a V =>
3) lay the V up on the tire and hook it to the tire treads,
4) start moving forward, letting the rope bring the chain up onto the tire,
5) stop and make sure your chain is hanging centered on the tire,
6) repeat 4 and 5 till the chain is wrapped around the tire stopping where the ends are accessible
7) make your connections
8) drive back and forth a few times to make sure they are seated and see if you need to adjust them.
I can put mine on the rears in 20-30 minutes per tire, this method works quite well for me and my brothers, mine are going on 18.4-30's
some of his are 20.8-42's they are heavy and awkward to install in any other method, such as throwing them up on top and trying to gather the ends up and then fasten them.
Good luck
2023 JOHN DEERE 8R370 LOT NUMBER 219 (A53084)
2023 JOHN DEERE...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
