Fast Idle Speed
/ Fast Idle Speed #1
kuboman
Canada
B3200, L5740,
Can anyone tell me the reason for the fast idle speed on my JD323D CTL?
It seems excessively fast in my opinion at 1200rpm. Can it be reduced?
/ Fast Idle Speed #2
Diesel engines produce more pollution at low rpms. If you tractor has Tier 3 or 4 the higher rpms keeps the system cleaner.
/ Fast Idle Speed
Is that the only reason or is there some mechanical reason for it? I would like to slow it down some if I can get a service man to do it.
/ Fast Idle Speed #4
Popular belief is diesels can idle at low rpm for long times without problem. That is not correct. Low rpms allows fuel to cool the chamber and increase fuel contamination of the oil. Idling the engine is good for cooling it down after working but not recommended for long periods.
As to adjusting the speed that may put it out of compliance for emission control. I would talk with the dealer before making changes.
/ Fast Idle Speed #5
It's 1300 on my 2025R. It was an awful 1650 on my buggy 1025R. Tried to reduce it on the 1025 but only got it down to about 1400-1500. Wasn't as easy as it was on my 4010. Haven't tried it yet on my 2025.
Why oh why does John Deere/Yanmar need the higher idle speed; whereas, Kubota does not. I tested a Kubota B2301. It idled at 1000.
Ralph
/ Fast Idle Speed
I understand the low idling and always bump up idle speed when I do idle but hate the idea of shutting down a racing engine. This is an electronic engine so the dealer will have to do it if he can or will.
/ Fast Idle Speed #7
The EPA laws may not allow the dealer to change it.
/ Fast Idle Speed
I'm in Canada so hopefully we can ignore that outfit.
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2022 EZ-GO ELITE...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
master diesel generator (A64553)
master diesel...
ATTENTION PLEASE READ (A64127)
ATTENTION PLEASE...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
