Paddy
Veteran Member
Hi all,
I have an old chevy Suburban, '94. I have had a fast blinker for a while but now just getting to it. I have changed out all the back bulbs. The front two side turn indicators were blown so they got replaced as well. So it appears all bulbs are working. Just using the turn signal, no brakes, works just fine. If the break is pressed L is OK but R blinks a bit fast. When either L or R is used, I see dimming the opposite side so it looks like they are both blinking
Before I changed out all the bulbs the dimming effect was more like flat out hazard light. There was no way to tell what direction I was indicating.
So, I'm guessing it's either a bad ground or some thing else. I just don't understand how the brakes or blinkers work fine solo but, not combined.
Thanks for any help.
