Oil & Fuel Farmtrac FT35 will not turn over, fuel injection pump concern
   / Farmtrac FT35 will not turn over, fuel injection pump concern #11
If you remove that cap on top of the injection pump and work the shut off cable in and out you should see the rack moving back and forth in the pump, if not then it is stuck or the linkage may be off the shaft on the back. Also the fuel feed pump could be bad. You can try disconnecting the supply line at the pump or just open the vent on a filter and crank it to see if it pumps fuel. The feed pump should produce about 20 psi of pressure.
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
40' CONTAINER (A52706)
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
Jumbo Quartz Slab 127.5" x 63.75" (new/unused) Est. Retail $2,200 (Pickup Location: Atascadero, CA) (A59225)
Jumbo Quartz Slab...
