Farmtrac - For real?
/ Farmtrac - For real? #81
Tastes great......
Less filling......
Hmmm, I see a pattern. [:)]
Have a good safe weekend everyone. Hope everyone gets some seat time in.
Don't forget to grease any exposed cylinders before winter storage and never use armor-all the seat! [;)]
/ Farmtrac - For real? #82
dbear said:
I still don't see how you guys can say that ergonomics are black and white. People are different sizes and shapes . . . If there is any clear-cut "fact" regarding ergonomics, that's it; pure and simple.
Slacker said:
Tastes great......
Less filling......
No secret, but I disagree.
Well short or tall, fat or skinny, if working a lever requires you to reach under your leg, then that is a simply clear cut fact, and that would be bad ergonomics.
Again, fat, tall, short, skinny, if the the loader control blocks the ingress/egress to/from the right of the tractor, that too is fact, and that would be bad ergonomics.
Front end loaders have been discussed by MossRoad and how his view of his front bucket. Most people who have tractors swear their loader is great. But I have to tell you, if you use one with a better view of the material is it almost like a religious experience. I've got many hours of use on many brands of fork lifts and other types of equipment lifting loads and have used many brands of tractors to lift loads. I have to tell you, tractors are horrible for FEL work. They are slow, offer low visibility, and are not very manuverable. All 3 of those things are facts. So anything that can be done to improve those things will improve the ergonomics, and that is not grey area. In commerical applications, where money is measured in time & productivity, you see machines that are far better at lifting than the tractors we use. My best forklift is articulated just like MossRoad's Power Trac. It fits down narrow aisles and maneuvers far better than my rigid forklifts. My rigid forklifts are far superior to any tractor. Again that is all fact. So when it comes to tractor FELs there are a lot of design issues we can look at and compare and while it might be opinion that one brand is better than another, it is fact that more visibility = faster use, safer use, more efficient use . . . and I think it is opinion that those facts are "better" but it is also hard to dispute.
Now there are other NON-ergonomic issues that also can be used to differentiate between tractors, some of those would include things like having exposes hoses that project up over the top of the hood that a branch can snag. Or a bucket without a toplip that is reinforced with a tube or box steel that runs from side to side. Or a few dozen other issues that we can discuss.
I've posted the attached photo before. It shows 2 of my tractors in my driveway. Both loaders have similar specs. Which do you think is safer, easier, faster to use?
/ Farmtrac - For real? #83
Can't tell if the thin-skinned comments were aimed at me or not, but let me say I'm trying to be hostile and I sincerely hope I'm not coming across that way. I currently don't own any tractor other than my lawn mower, so I have no "vested" interest; just my opinions.
I guess I'm just a little different. I look at control placement as a challenge - how can I efficiently and safely operate this machine as it sits?
I was raised on older Ford tractors from a 9N to a 9600 (used to sit on my mom's lap and steer starting when I was 5), and I don't recall ergonomics being an issue. I simply adapted myself to whichever machine I happened to operating that day.
Case in point, we had both a 5100 and 5200. The hydraulic valve for both is located under the seat. The 5100 had levers that just barely extended out from under the right side of the seat (one was slightly longer than the other); the 5200 had linkage that brought the levers through some sheet metal up next to the 3pt control lever (again one being slightly longer than the other). I always knew which lever I had, never had any issue operating either of these systems, nor do I think that, for me, one was ergonomically better than the other. That's just the way they were. Jumping ahead in models and years, both the 7700 and 9600 had all controls located in consoles to the right of the operator.
I do have to admit now that not having the gear shift levers between your legs is nicer, but again I never considered one style inherently better, nor safer than the other. Again, that's just the way they were. It's up to the operator to ensure safety.
I believe that function dictates form. That's why you have to look over your right shoulder a lot when running any 3pt or towed implement.
Tastes great...
/ Farmtrac - For real? #84
dbear said:
I still don't see how you guys can say that ergonomics are black and white. People are different sizes and shapes. And although I'm repeating myself, what you find comfortable, I may not. If there is any clear-cut "fact" regarding ergonomics, that's it; pure and simple. All the rest is gray.
Just because you find something comfortable doesn't mean it is good for you. Take slouching in a chair, for instance. It sure feels good until you get up after a few hours of it. Then your back is stuck in that position. Or incorrect computer keyboard height, or mouse placement and its affects on your shoulder, wrists and fingers. All that stuff is well documented ergonomics, so it really is pretty black and white. Same measurable data applies to tractors, trucks, cars, any equipment, really.
/ Farmtrac - For real? #85
No thinned skinned comments were aimed at anybody. I just fired that out there shotgun-like to see what I'd hit. ;)
dbear said:
....I believe that function dictates form. That's why you have to look over your right shoulder a lot when running any 3pt or towed implement....
That's why there are so many hunched over old farmers. Too many years of hard work behind un-ergonomic machinery. :eek:
That's also why I find the Power Trac design more ergonomic. All the implements are out front where you can see them. Of course, that doesn't work for plowing dirt, too well, so get some mirrors for plowing dirt. But for the majority of home owner projects, it is a superior design.:D
/ Farmtrac - For real? #86
On my HST tractor, the loader controls do not block access from the right however there is no step on the right. When I inquired about adding a step on the right, I was told it wasn't recommended due to the forward/reverse pedal locations would make mounting or dismounting on the right dangerous when the engine was running. Since then, I frequently get off the tractor when its running (picking up rocks when tilling,etc...) but have made it habit to always do so from the left (running or not).
/ Farmtrac - For real? #87
shvl73 said:
I was told it wasn't recommended due to the forward/reverse pedal locations would make mounting or dismounting on the right dangerous when the engine was running..
Certainly depending on the size of the tractor, the floor layout, etc it might be an issue (when the tractor is running) but that would largely be a tractor specific issue. For example, within any given brand there may be several floor layouts for the various size machines. Still, the fact is you can exit the right of the tractor should you choose to or, worse yet, should you need to in an emergency.
MossRoad said:
. . .incorrect computer keyboard height, or mouse placement and its affects on your shoulder, wrists and fingers. All that stuff is well documented ergonomics, so it really is pretty black and white. Same measurable data applies to tractors, trucks, cars, any equipment, really.
Exactly.
Just as you admit that the gear shift between your legs is not ideal, I would suggest you'd be willing to admit that other things are also better or worse.
As to safety, the key to good ergonomic design is that it allows the operator to focus on the job and not have to focus on 10 other things.
The point with tractors is to keep the operator working safer by using smart design (not necessarily whiz bang gimmicks). For example, many fenders have 2, 3 or even 4 levers on them to control various functions. Good ergonomic design would be to make sure the operator could easily reach all of them, and could operate them without leaning, across their full sweep of movement. Better ergonomic design would be to color code them so the operator would know at a quick glance by color what lever was what. Even better design would have the levers with colored handles AND different shapes so you could FEEL or SEE the difference. Those little things make it easier, more efficient and safer to operate the machine.
/ Farmtrac - For real? #88
Just realized I left out the word "not" from my above post. Should read that I'm NOT trying to be hostile...Proof again that spell checkers can't catch everything...
I guess I'm not expressing myself well here. The point I was trying to make is just because a workstation might be better ergonomically designed doesn't inherently make it more efficient. A lot of that comes down to the individual.
Granted I never did any actual scientific studies, but I'd be willing to bet I was as just as productive on the 5100 as I was on the 5200, or even the 7700. Never made a difference to me where controls were located; I always knew where they were. Reaching over, or down is still reaching and no control was ever that far away as to require leaning or stooping way over to get a hold on them.
Now how all this relates to the FarmTrac 270, I'm not 100% certain, except to say that, pending a more thorough seat-of-the-pants test, for me, I firmly believe it would work as well as, and be just as comfortable as any of its more well known cousins. Guess I haven't been convinced of the need for, not to mention the added cost of, many of the electronic "refinements" manufacturers add nowadays. Seems I’ve heard plently of stories about problems with those electronics. For what I would use a tractor for, I just feel they wouldn’t be that big of an advantage to justify that cost. Hey, I’m cheap. What else can I say?
/ Farmtrac - For real? #89
I think a lot of people are confused about ergonomics. It has NOTHING to do with 'electronics' and I will totally agree that you don't need electronics on tractors. None of mine have them except for one that has an electronic hour meter. Other than that, mine all have simple analog gauges. Ergonomics is about the placement and the design and the use of the controls. It is directly related to industrial design and has been proven in office and industry setting to improve productivity, comfort, and safety.
Again, ergonomics is NOT electronic do-dads or any other whiz-bang things that get added to some tractors.
/ Farmtrac - For real? #90
Gauges? You have gauges? :D
/ Farmtrac - For real? #91
Bob, I'm not confused in least about ergonomic vs electronic. I fully believe marketing people are. Almost all of those do-dads are billed as making it easier, more comfortable and safer to operate - aka ergonomics.
/ Farmtrac - For real? #92
OK well then the marketing people can be blamed for many things. However, per this discussion about the ergonomics of the Farmtrac tractors, never once was I referring to anything to do with electronic tom-foolery. All my issues reside with the physical shape and/or placement, or mis-placement of levers, controls, etc.
/ Farmtrac - For real? #93
And again, I maintain that much of your displeasure with control location is subjective. Also, I don't believe you ever answered my question regard which model(s) you were referring to, utility or compact.
Face it, we're just not gonna agree on this...
/ Farmtrac - For real? #94
27 to 40hp Compacts. The utilities would probably have similar issues as some of those are based on 1980's Ford designs and in the 80's the concept of ergonomics never made it to the tractor designs.
As for agreeing, we don't have to. The facts speak for themselves and as has been pointed out by others, ergonomics are proven to make things more comfortable, safer, easier to use, and they are quantifiable.
/ Farmtrac - For real? #95
Bob, I agree ergonomics are important - just one look at say a 9N and the same era JD, AC, or IH (all rear mount machines) and one can easily say the 9N is a better ergonomic design. Maybe this why I don’t mind what you would call excessive lever throw.
However, what I don't agree on is that ergonomics are black and white. Using your computer workstation example, and according to OSHA's website (OSHA Ergonomic Solutions: Computer Workstations eTool - Components - Monitors, there are gray areas with regard to said workstation layout. Distance should be 20" to 40" from eyes with the top of the monitor at operator eye level (this, due to range of individual height, leaves a lot of wiggle room). Wrists should be in-line with forearms which should be close to the body. Again, individual body shapes and sizes dictate that there be a wide range of acceptable optimum ergonomic positions.
Hence my arguments that regardless of whether we're talking computers, tractors, cars, or toasters:
A. Ergonomics, outside of the upper and lower limits, is not black and white, but largely gray due to operator physique.
B. Because of "A", fine tuning operator position and comfort ergonomically is a highly subjective-based decision directly dependent upon said operator's physical dimensions.
/ Farmtrac - For real? #96
Sure a short person and a tall person are not going to fit like an average person. But if the movement to reach for an out of place control is no good for anyone of any size, that is pretty black and white. If you constantly have to reach for something that could be put closer, that is not a good design.
At my employer, we have adjustable keyboard trays, mouse trays, chairs, monitor stands and even adjustable desks (the entire desk top moves up, down and tilts) for the professional typists. All so that they can get the proper arangement for their different sized bodies. Many folks like to reach for the mouse to do a task that a simple keyboard shortcut is in place for and would be faster and avoid that reach. They don't see it as a big deal. Until you add up that they could be saving hundreds of arm motions an hour, thousands a day, hundreds of thousands per year and millions over the span of a career. Could be the difference between a happy retirement or a lifetime of pain.
/ Farmtrac - For real? #97
Have you actually ever seen one of the 6 and 7 series utility tractors? Ever sat on one? I would suggest you go to your nearest Farmtrac dealer before you make these blanket statements.
KB
/ Farmtrac - For real? #98
KB
Have you actually made a constructive post yet? I would suggest that before you criticize other people you build up your own reputation by contributing actual information rather than attempting to tear down other folks.
/ Farmtrac - For real? #99
Bob_Skurka. Speaking of reputation. With your last post you're doing wonders with yours or building a new one. I could be wrong but I think that was uncalled for. He asked two questions of you. Got no answer to either.
Just answer his questions since you're the expert here. And chillout before you do.
/ Farmtrac - For real? #100
Greetings,
This is my first post. I am a semi-old guy with a brand new Farmtrac 360 TLB. Don't know "nuthin" bout no ergonomics, and my Ph.D. is a long way from having anything to do with agriculture, but I did grow up in Kansas in the Fifties, and I have steered a few tractors around those flat fields. While this one isn't perfect, it beats the wheel weights off of anything I used from AC/JD/Case, etc etc. back in the old days.
It's almost like driving my RX300 around the lower pasture, but with a little more pulling power and better four wheel drive. Then again, it doesn't have heated seats either.
Were I designing this machine, I would put the hydro controls for the FEL a little lower on the right and the shuttle shifter a little higher, and for we six foot and over guys, provide a little more room for the legs. But these are minor points. It is such a pleasure to use and drive, I can overlook these flaws.
Then again, I've only logged 11 hours on it, but I have moved several tons of dirt and rocks making a hillside pad for my soon-to-be-delivered tractor shed, and every hour was a blast. If only my grandson were there to help with his Bob the Builder rigs.
I looked at JD and Mahindra. It finally boiled down to a local dealer with a long history, great service and good parts room, and he was a real gentleman...with a great no interest three year financing deal. How can you beat that with 5.25 percent CD's available at your local bank?
No regrets with this machine so far. Well, except for nearly breaking up the 42 year marriage, but once I plant some trees, those troubled waters should subside as well.
This forum is great and I appreciate all the comments and insights. Hope I can provide some insight as I work with the FT in the years to come.
It would be great to have our own Farmtrac forum. Any takers?
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
7' Disc (A62613)
7' Disc (A62613)
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
Landpride PL3048 (A64126)
Landpride PL3048...
2006 Xtreme Hawg Hauler (A64127)
2006 Xtreme Hawg...
