Farmtrac Filter. Farmtrac Update
   / Farmtrac Filter. Farmtrac Update #11
I have a Farmtrac 360DTC and was wondering if anyone knew where i could get an owners manual.
   / Farmtrac Filter. Farmtrac Update #12
I have a Montana 3840, which I hear matches a Farmtrac dtc360. Does anybody know the numbers for a hydraulic filter?
I believe your model is found on the attached sheet.
  • tractor filters.pdf
   / Farmtrac Filter. Farmtrac Update #13
Help!
I just bought a used low hour 2006 Farmtrac 665 DTC with a 5440 loader.
Needless to say I did not get any manuals.
I sure would like to talk to someone who has this model and pick their brain.
ANY info appreciated.
   / Farmtrac Filter. Farmtrac Update #14
I am in need of a steering pump filter and O ring kit for my Farmtrac 60 with hydrostatic steering. Does anyone know where I could get the filter kit?
Thanks for the Wix filter info.
   / Farmtrac Filter. Farmtrac Update #15
I just change my PS filter this winter. My former FT dealer still has a good supply of FT filters in stock.
My area FNH dealer has them as they use the same pump on some old Ford units. Take the filter to a FNH dealer in your area that was a old Ford tractor dealer. Betcha' they can fix you up.
   / Farmtrac Filter. Farmtrac Update #16
A 1712 NAPA worked fine on my Farmtrac 60.
   / Farmtrac Filter. Farmtrac Update #17
The PDF is a bit confusing, at least on this computer. Does someone have NAPA numbers for the hydraulic filter, HST filter and (motor) oil filters?
I'm almost to 400 hours and the hydraulic filter light has come on. Oil level is a bit low, but not serious due to a leak I repaired.
'04 (as I remember) 390HST
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
Deere 410L (A53317)
Deere 410L (A53317)
