Farmtrac 665 Dies Going Uphill,
   / Farmtrac 665 Dies Going Uphill, #11
The solenoid is a built-in part of the pump. When this tractor quits running, are you sure you then have 12 volts at the solenoid? You will need to verify that's the case. In other words, you could have an electrical problem up in the dash. If the solenoid is defective, then you would need to remove the pump and take it to a service shop specializing in Bosch pumps. On mine, the fix was simple....a bad clip-on connector...
   / Farmtrac 665 Dies Going Uphill, #12
Sourwood
I'm very interested in the problem with your tractor dying going uphill. Have you found the problem? Please let us know, I might have that same problem someday....
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
2017 Takeuchi TL12R2 Skid Steer, S/N 412100259, Kubota Diesel Engine, Joy Stick Operating Controls, (A59076)
2017 Takeuchi...
2020 MACK P164T (A58214)
2020 MACK P164T...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
2020 DRAGON ESP...
