FarmTrac 60 Starter Removal
/ FarmTrac 60 Starter Removal #1
blackwjb
Tigerville, SC
JD 3020
Anyone removed the starter to clean the pinion as specified in the operators manual? I'm having trouble getting the rear bolt.
Jim in SC
/ FarmTrac 60 Starter Removal #2
I'm the guy you emailed at Redbay Farm. Any luck on removing the starter yet?
/ FarmTrac 60 Starter Removal #3
I replaced the one on my 555 last year. You need to put enough extensions together to sneak behind the starter . IIRC the bolt is hidden and getting it started was way worse than getting it out.
/ FarmTrac 60 Starter Removal #4
Anyone have info on wiring harness schematic for a 02 Farmtrac 45
Tia
/ FarmTrac 60 Starter Removal #5
I have a print for a farmtrac 60 but your welcome to have a copy I’m not sure if it’s for my ft60 but it’s all I could find I’m looking for a print for my ft60
/ FarmTrac 60 Starter Removal #6
What is a FarmTrac 60? I have a small model of one, or as least something with FarmTrac 60 decals on it, made of sheet metal. Typical India hand-made simple construction.
Anyone?
