Farmtrac 60 running wide open
   / Farmtrac 60 running wide open #1
lbaldwin
Farmtrac 60
I have a 60 that sat for 2 years and it runs wide open when it fires up. Also the kills switch has no affect.
Hoping for something simple to try before pulling the pump.
Thanks
   / Farmtrac 60 running wide open #2
Take the cover off of the pump and free up the sliding "Rack". Sounds like it is stuck at high throttle.
   / Farmtrac 60 running wide open #3
Remove the side cover (2-4mm Allen)
The control rack is stuck..
U must be VERY CAREFUL.,
EVERYTHING is made of pot metal and breaks easily.!!
When was the last time u put oil in it.?
U might get lucky spraying it down with some penetrating oil and letting it sit for a day..
I just got done w one and had to replace the camshaft & bearings..rollers and springs..
I can rebuild it, several hundred less than buying new..
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
1262 (A50490)
1262 (A50490)
2011 Cadillac SRX LUXURY (A50324)
2011 Cadillac SRX...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
