Farmtrac 60 running wide open
   / Farmtrac 60 running wide open #1
lbaldwin
Farmtrac 60
I have a 60 that sat for 2 years and it runs wide open when it fires up. Also the kills switch has no affect.
Hoping for something simple to try before pulling the pump.
   / Farmtrac 60 running wide open #2
Take the cover off of the pump and free up the sliding "Rack". Sounds like it is stuck at high throttle.
   / Farmtrac 60 running wide open #3
Remove the side cover (2-4mm Allen)
The control rack is stuck..
U must be VERY CAREFUL.,
EVERYTHING is made of pot metal and breaks easily.!!
When was the last time u put oil in it.?
U might get lucky spraying it down with some penetrating oil and letting it sit for a day..
I just got done w one and had to replace the camshaft & bearings..rollers and springs..
I can rebuild it, several hundred less than buying new..
10x16.5 Tire Assembly (A51039)
10x16.5 Tire...
John Deere 980 Field Cultivator (A50514)
John Deere 980...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A51039)
2009 Freightliner...
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2021 Takeuchi TL12V2 Skid Steer (A51242)
2021 Takeuchi...
