Farmtrac 60 Injector Pump leak?
   / Farmtrac 60 Injector Pump leak? #1
Farmtrac602003
Farmtrac 60
I recently changed the oil in the 2003 tractor (1000+ hours). I topped off the injector pump oil at the same time with the same oil. Since then, as expected, some overfill drained out the drain from the drain line. Now though, as the tractor is running it seems that there is a pretty consistent drip. It doesn't quite smell like diesel but does seem to be a little reddish (offroad diesel color).
I added marvel mystery oil to the engine oil (not the injector pump), I added diesel kleen to the last tank. In addition to the injector drip I am also seeing a light mist/and oil dripping from the crankcase vent tube.
Tractor is running well, oil pressure is about 50 psi, Oil level still the same, no overheating.
Should I worry?
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2017 CATERPILLAR 259D SKID STEER (A52709)
2017 CATERPILLAR...
2018 Ford F-150 (A55973)
2018 Ford F-150...
2012 NISSAN AWD Rogue (A56859)
2012 NISSAN AWD...
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
