Farmtrac 555 injection pump (Bosch) vs Ford (cav) for replacement
   / Farmtrac 555 injection pump (Bosch) vs Ford (cav) for replacement #1
swamptractor
Louisiana
Farmtrac 555, Ford 3000, Ford 6610
Has anyone ever tried replacing the injections pump on a 555 with an older CAV pump from a ford? Any thoughts? I know other parts such as the injector lines and feed lines would need replacing as well. I致e already swapped out my fuel filter housing for the older ford style because those filters were more readily available to me than replacement WIX or other comparable one for the original ones. I know a 3910 and a 3430 both had a 3.1l 192ci engine. That would seem to be a decent starting place for this project.
   / Farmtrac 555 injection pump (Bosch) vs Ford (cav) for replacement #2
That痴 a good question I will Check with my mechanic that was a Ford dealer mechanic for 30 + years he痴 worked on both of my 555痴
It would indeed be nice to know. Even if one had to go as far as replacing injectors you could still save over $500 compared to the price of the Bosch pump.
   / Farmtrac 555 injection pump (Bosch) vs Ford (cav) for replacement #4
My Tractor man says probably not but he痴 not 100% sure of it. The Bosch system works really well just really loud
Works well until it fails anyway. I suppose it would come down to engine timing. Maybe an examination of internal components will shed some light on this.
Sims Snow Board (A51573)
Sims Snow Board...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2008 CATERPILLAR 320D L (A52472)
2008 CATERPILLAR...
