farmtrac 535 wet brakes
   / farmtrac 535 wet brakes #1
plumbpaul
kenner,louisiana
farmtrac 535
while working on the tractor this weekend my bolts started to back out of back right hub and started leaking oil. caught in time before hub came off tractor. Now my right brake does not work. its a framtrac 535 2007 with wet brakes is it something i can fix with breakdown sheet or more to it .
   / farmtrac 535 wet brakes #3
What do you mean by not working, slow stop, no stop, catching , squeaking. Is it adjusted
   / farmtrac 535 wet brakes #5
It is the actuator shaft. It is not locked into the brake hub. Just take the linkage from the brake pedal loose and rotate the shaft back and forth a little and it will lock back in. There is a slot inside the hub that it needs to fit in to actuate your brakes. Once you feel the tension on the shaft reconnect you linkage to the pedal and you will be in business.
Mini Skid-Steer Forks (New/Unused) (A59225)
Mini Skid-Steer...
2014 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58018)
2014 FREIGHTLINER...
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2019 Chevrolet Tahoe SUV (A55973)
2019 Chevrolet...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
