farmtrac 535 wet brakes
   / farmtrac 535 wet brakes #1
plumbpaul
kenner,louisiana
farmtrac 535
while working on the tractor this weekend my bolts started to back out of back right hub and started leaking oil. caught in time before hub came off tractor. Now my right brake does not work. its a framtrac 535 2007 with wet brakes is it something i can fix with breakdown sheet or more to it .
   / farmtrac 535 wet brakes #3
What do you mean by not working, slow stop, no stop, catching , squeaking. Is it adjusted
   / farmtrac 535 wet brakes #5
It is the actuator shaft. It is not locked into the brake hub. Just take the linkage from the brake pedal loose and rotate the shaft back and forth a little and it will lock back in. There is a slot inside the hub that it needs to fit in to actuate your brakes. Once you feel the tension on the shaft reconnect you linkage to the pedal and you will be in business.
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2015 MACK GU713 (A50854)
2015 MACK GU713...
American Sanders EZ-8 Electric Floor Sander (A49461)
American Sanders...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A51039)
2023 New Holland...
