Farmtrac 535 Fuel Problem
/ Farmtrac 535 Fuel Problem #1
TR16
Stonewall, LA
Farmtrac 535
I have a Farmtrac 535 that sounds like it's fuel starved at 1/2 throttle or more. When idling, runs smooth. When you give it half throttle or more it starts sputtering. Almost sounds like a miss in the engine. When I pump the fuel feed pump manually, it levels out and sounds great for a few seconds then goes back to sputtering. Makes me think fuel is not getting to the injector pump. I disconnected the feed coming from the fuel tank, strated the engine, and fuel flow looks great. But when I disconnected the pipe on the other side of the feed pump (running from the fuel feed pump to the filters) and then started the engine, there is no fuel flow at all. It seems obvious that the feed pump is bad but I'm thinking that's too apparent. I took the feed pump off and there's really nothing to it. I don't see how it can go bad.
Can a fuel feed pump go bad? Or is there something that pulls a vacuum that I need to be looking for?
TR
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2019 TerraGator 7300 Spinner truck (A63118)
2019 TerraGator...
2021 PETERBILT 388 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2021 PETERBILT 388...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
