Farmtrac 45 power steering leak
   / Farmtrac 45 power steering leak #1
whiteoak
West Virginia
MF 2615, MF 35, Farmtrac 45
My 2003 Farmtrac 45 has developed a power steering leak underneath the steering column. Fluid is running down side of block. Tractor has 200 hours on it. Could it be a fitting or seal?? Also, I'm not sure where to refill the power steering fluid. Bought the tractor used and didn't get a manual with it.
Tractor also seems hard to start. I have to crank awhile to even get it to hit. Tempature doesn't seem to matter. Has anyone experienced similar problems. Any help will be appreciated. Thanks!
   / Farmtrac 45 power steering leak #2
More than likely there is a leak on one of the lines coming from the steering pump. The pump is located in what I can only describe as a "canister" toward the front of the motor. It has a plug and that is where you can add hydraulic fluid to it. Take the sheet metal off and see which line is leaking. When filling up your steering fluid be sure the tractor is running, fill it up, turn wheels to full left and then full right and then refill is necessary.
2025 CATERPILLAR 265 SKID STEER (A51242)
2025 CATERPILLAR...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52128)
Toyota 6FGU25...
100 Safety Cones (A47384)
100 Safety Cones...
2016 Ford Fusion Passenger Car, VIN # 3FA6P0G79GR191653 (A50324)
2016 Ford Fusion...
