Farmtrac 435 not starting
/ Farmtrac 435 not starting #1
snowman4evr
South Alabama
Case 1394 AWD Rear Duals, Case 75A, Kubota M9540
Hello All, Was hoping to get some help with this Farmtrac 435.
/ Farmtrac 435 not starting #3
The solenoid on the side of the inj pump is just a cold start solenoid, it just advances or retards the timing for easier starting.
The solenoid by the lines is the shut off solenoid, some are powered (12v) to run and some are powered to shut off..
Thanks for the wiring schematic, and thank you Pump guy! All right, its running now with that switch/sensor bypassed, and power now to the shut off solenoid.
But the question is what was that switch/snsor on the side of the head, that the shut off solenoid was getting its power from? Iam not sure that wiring schematic is for this tractor. This tractor has the thermostart, no glow plugs.
I took a few pics of it to give an idea of its location on engine. its the one with the black twisted wires. This feeds power to that shut off solenoid.
/ Farmtrac 435 not starting #5
Is the black twisted wires going to your thermostart.?
If yes, something is bad wrong..
The thermostart should only be active when u turn the key switch a certain way.. either to the left or to the right, just before the start..
No. Power is going to that switch/sensor, but nothing is coming out of it. One is hot going to the sensor and the other black twisted wire feeds to the injector pump shut off sol.
UNUSED FUTURE 72PRO-72" MULCHER (A60432)
UNUSED FUTURE...
Cat CB24B (A60462)
Cat CB24B (A60462)
2017 Ford F-150 Pickup Truck (A59230)
2017 Ford F-150...
4ft Mini Skid Quick Attach Rotary Cutter (A61306)
4ft Mini Skid...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A59905)
2017 INTERNATIONAL...
2020 Ford F-250 Ext. Cab Service Truck (A59230)
2020 Ford F-250...
