farmtrac 360DTC
   / farmtrac 360DTC #1
fullofquestions
FT360DTC-S/N360DF4AG0166
I have a Farmtrac 360DTC S/N 360DF4AG0166, not sure what year it is. Just bought it. I really need a wiring diagram. None of the lights work on the dash or headlights, turn signal, or emergency flashers . Fuel gage doesn't work, charge light, oil pressure light, glow plug indicator, hyd. oil filter, parking brake , power take off and high beam light are all not working. so I really need a wiring diagram so I can start chasing wires and checking grounds. Any help out there? I am a mechanic on aircraft so I can chase this problem without a diagram but it will take much longer to find the problem or problems. Any help would be much appreciated.
   / farmtrac 360DTC #2
I have no schematic but does the tractor start and run normally? Do you have power to the fuse box? Is there a fusible link somewhere?
   / farmtrac 360DTC #3
Sir I am an old wire out wireman and I wish I was there to help. Wireing diagrams are useless to me on that type equipment. Most of the time athey are not schematic, but just the elemtary and very difficult to follow. Yea I be exactly like you and make sure that ground was there and they might break it in a safety switch or something. Then you might get a temporary positive and touch around and get a little motivation. Stay in touch and good luck sir
2021 Snake River 14ft T/A Dump Trailer (A49461)
2021 Snake River...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2013 INTERNATIONAL...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
