Farmtrac 360dtc will not stay running
   / Farmtrac 360dtc will not stay running #1
rdgirls
cambridge md
farmtrac 360dtc
I have a farmtrac 360dtc that will start up every but when the key goes to the run position it clicks and shuts back off. Any one have this problem or have ideas where to start looking, I checked all the fuses and there good.
   / Farmtrac 360dtc will not stay running #2
see if it will run with the sw out of the circuit, it may not allow the alt to charge but it will tell u if the ign sw is the issue. Its a diesel....yes ?
   / Farmtrac 360dtc will not stay running #3
Don't assume your fuses are good by looking at them. Somewhere on here is a similar thread I started.
Each and every fuse looked fine on my 360DTC, but when I finally bit the bullet and changed them because I was running out of options, it started and ran fine. Oh, and mine acted the EXACT same way before changing the fuses.
edit: here is my post
http://www.tractorbynet.com/forums/...ong-360dtc-hyd-start-problem.html#post1726663
Note: the fuse to replace was labeled KEY.
Cat TH407C Telehandler (A53472)
Cat TH407C...
2006 CHEVROLET SILVERADO 3500 FLATBED (A55745)
2006 CHEVROLET...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
King Kutter TG72 Rotary Tiller Tractor Attachment (A55851)
King Kutter TG72...
