Farmtrac 35 Revving high
   / Farmtrac 35 Revving high #1
Billynwz
FARMTRAC 35
I don’t know much, if anything, about tractors. Trying to help in laws. The tractor will start but then it will rev up. The engine kill cord won’t work and the only way to shut it down is to cut off the fuel line. I’m mowing 9 acres with a riding lawn mower.
   / Farmtrac 35 Revving high #2
If it has an “inline” injection pump on it..(lines come off the inj pump in a straight line)
Remove the side cover and look at the springs.. u may have 1 or 3 that are broken..
u do know the pump takes oil, right.?? If not, it’s probably rusted and that’s why it’s running away..
Save your pennies and give me a shout..
   / Farmtrac 35 Revving high #3
Where is the side on go or side or on pump mine did the same thing once before n I forgot how the old farmer fixed it I know we took plug out of the pump on top it was rusty but after a few mins she ran again but u can’t figure out how Rayo do again
   / Farmtrac 35 Revving high #4
If u can’t figure out where the side cover is, u don’t need to be working on the pump..
Time to hire a mechanic or do some searching on the internet..
   / Farmtrac 35 Revving high #5
I Have a farmtrac 35 and need to rebuild the injector pump. I cannot find a service manual on it. Can somebody help me? Also what kind of oil do you put in the pump? The Pump is a Bosch F002AOZ295.
   / Farmtrac 35 Revving high #6
U put the same oil as u put in the engine..
I rebuild them..
U won’t find a manual, they aren’t for the layman to work on..
If u want to get in touch with me.. u can click on my screen name and start a conversation..
Or put my screen name at aoldotcom in your home mail service..
   / Farmtrac 35 Revving high #8
Same thing on my tractor. Need some help
   / Farmtrac 35 Revving high #9
We check the oil in our injector pumps every time we bale hay. Every time before we use them hard for an extended period. From what I just read, you folks need to be checking yours. Just like checking engine oil, that often. I know, I sound crazy, but we ain't never had injection pump trouble. Out of seven tractors. One is a newer cab tractor. Five are from 1980 to 1995, one is 1958. All work fine. 58 model is only one we didn't have from beginning. Three others were a year or so old when we got them. All those tractors are between me, brother, and dad.
   / Farmtrac 35 Revving high #10
Take the side off and see what it looks like inside. May need an oil shower sprayed in there. May have a broke spring. Governor stuck. Need to have a look see.
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
7pc Mini Excavator Attachment Set (A51573)
7pc Mini Excavator...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
