Farmtrac 300DTC PTO
Status
Not open for further replies.
   / Farmtrac 300DTC PTO #1
rangerric
I cannot seem to get the PTO to operate properly on my new Farmtrac 300 DTC. I use a 5 foot finish mower with no problem, but when I hook up to a 5 foot rotary cutter it engages like two freight trains colliding, whether in manual or independent mode. It shears the bolt pin on the cutter three out of five times it is engaged, especially when engaging it with the clutch. The cutter works smoothly on another tractor. Does anyone have any idea what I am doing wrong?
   / Farmtrac 300DTC PTO #2
I have a FarmTrac 270 but it's a whole different setup. May I suggest you post your questions in the "All Other Brands" section. There are some very knowledgeable owners and dealers that hang out there. Also Montana has the same LG tractor except it's not that pretty FarmTrac blue. But the Montana fellas are very helpful as well.
John
Thanks!
   / Farmtrac 300DTC PTO #4
I'll be watching this thread as I've got a new 360TLB and a new 5' bushhog that I have not used yet. Hopefully I don't have the same problem!
   / Farmtrac 300DTC PTO #5
Dupe thread. Closed.
If you need a thread moved, simply click on the Notify Moderator (red triangle) icon.
Status
Zero Turn Mower (A55853)
Zero Turn Mower...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2024 Timpte 40ft Hopper (A56435)
2024 Timpte 40ft...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
Rooster Weathervane (A55853)
Rooster...
