farmtrac 270d
   / farmtrac 270d #11
agequipt said:
Some one asked lift on 5040 loader?
The origional spec was 1000lbs then up graded to 1200lbls at full height
no change in the physical machine just a PRV setting per Eng in Tarboro.
Thanks for the info.
Just curious. PRV = pressure relief valve, I assume.
Eng = ?
engineers?
   / farmtrac 270d #12
I have a 270DTC that just turned over 200 hrs. The tractor has been very dependable, and is quite a workhorse. Only trouble I've had is sheered bolts in the front end loader brackets (I think this was mostly my fault for not checking them for tightness more often), and a broken clutch pedal return spring. I couldn't find a dealer with the spring in stock, but found one that worked at Home Depot for $1.25 I was supposed to have another year warranty on the tractor, but I'm not worried about it. I just replaced all the filters (oil, hydraulic, fuel and air) for less than $50.
2012 Ford Fusion (A56859)
2012 Ford Fusion...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2015 International Bucket Truck (A55973)
2015 International...
More info coming soon! (A55851)
More info coming...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
