Farmpro 2430 hydraulic power steering
   / Farmpro 2430 hydraulic power steering #1
Rickpit
Yarmouth, Nova Scotia
FarmPro 2430
:confused: having issues with steering. Changed fluids in hydraulics two months ago and since can't steer properly. Steering is loose and have to move steering wheel a few rotations a lot of the time before can get wheels to move. Can't use in this condition. Has anyone else had similar issues
   / Farmpro 2430 hydraulic power steering #2
Have you checked for air in the steering circuit.
You may have a suction leak, hose or fitting, causing the air to impede you operation.
I'm not quite sure how to bleed air out of this type Tractor but have done what a Kubota dealer said to do if it was similar to what the this tractor has but it works no different than before. Right now I took it to a truck repair shop to see if they can decifer what the issues are. I'm not a mechanic and was frustrated and did not want to hurt anything further. I could use the tractor right now so took it to them. They are supposed to work on it today. Thanks for posting on this J_J and will keep you posted on what the shop may find. I posted this to see if anyone else ever had a similar problem. I'm hoping I'll hear from them soon and I'm hoping it may not be too expensive of a fix.
7x12 Homesteader Dump Trailer (A51572)
7x12 Homesteader...
CONTACT INFO (A53084)
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A51572)
1996 International...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
Toro Mower (A50324)
Toro Mower (A50324)
Caterpillar 308E2 CR Midi Excavator (A52377)
Caterpillar 308E2...
